Manual Blacklist not working
  • 1.  Manual Blacklist not working
    Posted Jan 18, 2014 05:12 PM
    All,
    I used the GUI of a IAP-93 (running software version 6.3.1.1) to blacklist a MAC address and yet the wireless client still continues to associate to the AP and able to transmit packets as if the blacklist was never performed. I even tried to do it at the CLI and still same failed result. I performed these steps to enable it:
    Web UI: Security>Blacklist (tab)>typed mac addresses into box under title, "Manual Blacklist", clicked 'Ok'.
    CLI: conf t, blacklist-client <mac-address>, end, commit apply
    I even tried even rebooting the AP afterwards and still it is not working.
    Has anyone come across this problem? Is there a bug with the software?
    Adil
  • 2.  RE: Manual Blacklist not working
    Posted Jan 18, 2014 05:36 PM
    Apologize , missed the IAP part
  • 3.  RE: Manual Blacklist not working
    Posted Jan 18, 2014 07:50 PM
    Yes, I tried from the CLI. This is an IAP-93 so there is no 'stm ...' command. The command is "blacklist-client <MAC address>". I tried it both ways - CLI and web UI. I checked the admin guide and I believe I did all the required steps to enable it (steps outlined in my original post).
    Adil
  • 4.  RE: Manual Blacklist not working
    Posted Jan 21, 2014 01:40 AM
    What OS you are using?
  • 5.  RE: Manual Blacklist not working
    Posted Mar 06, 2014 05:36 PM
    The IAP-93 is running code version 6.3.3.1-4.0.0.1_41049. Has this issue been fixed in a later release?
    Adil
  • 6.  RE: Manual Blacklist not working
    Posted Mar 07, 2014 02:57 AM
    Have u enabled Black Listing on SSID ???
  • 7.  RE: Manual Blacklist not working
    Posted Mar 08, 2014 09:50 PM
    That was it! I enabled blacklisting for the SSID and now it is working.
    Thank you so much!
    Adil
  • 8.  RE: Manual Blacklist not working
    Posted Feb 20, 2014 12:19 PM
    Did you ever get this working? I've opened a post on the IAP forum with exactly the same issue!
    Regards
    Mike
  • 9.  RE: Manual Blacklist not working
    Posted Feb 26, 2014 08:57 AM
    Hi Mike,
    I never got this to work. I think it is a bug in the software. I tried do
    it using both CLI and GUI and same failed result. If you come across a
    working solution, please let me know.
    Adil
