Hello i was wondering if you really need to configure the manual cluster for the coa to work ? you know to terminate the session and what do you need for onguard to work
If the answer is yes do i just configure the virtual IPs, the vlan vrrp and the vrrp id and the passphrase and that's it?
What about the virtual ips which is different in each controller what fw permissions they need? it just that i don't understand how it works
If anyone can tell me please
Carlos
