Manually configure IAP 275 channel
  • 1.  Manually configure IAP 275 channel
    Posted Nov 03, 2016 05:10 AM
    I have manually configure IAP 275 channel with following CLIs:
    arm
    wide-bands none
    a-channels 36,40,44,48
    g-channels 1,6,11
    min-tx-power 18
    max-tx-power 28
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    After I committed the commands, I found APs are still running other channels:
    show ap arm history
    Interface :wifi0
    ARM History
    Time of Change       Old Channel  New Channel  Old Power  New Power  Reason  Result
    2016-11-03 09:29:28  116          116          27         21         P-      Configured
    2016-11-03 09:26:54  100          116          27         27         M       Configured
    2016-11-03 09:22:07  116+         116+         24         27         P+      Configured
    I am not clear why this happend? Firmware version  (6.5.0.0-4.3.0.0_56428).
    Thank you all in advanced!
  • 2.  RE: Manually configure IAP 275 channel
    Posted Nov 03, 2016 06:15 AM
    Hmm,
    I tried this first on 4.2.0.3,
    Having my IAP103 on channel 36 at first then removed all allowed channels except for 48 and it changed instantly (due to flag invalid channel). This method with removing current channel and adding another one worked several times to force a channel change.
    2016-11-03 09:40:10  36           48           21         21         INV
    However, when upgrading to 4.3.0.0 things did not behave the same.
    My AP came up on channel 116, I then removed all channels from allowed channels except for 40. It then changed to 40 as excepted (not with the INV-flag but with P- ?!). Removing channel 40 and adding channel 100 did not trigged a channel change on the IAP.
    I did a reboot and the IAP came up with channel 100. Removing channel 100 and adding 40 it changed once again with P- flag (which is odd), but after that i can't change channel until a reboot.
  • 3.  RE: Manually configure IAP 275 channel
    Posted Nov 03, 2016 08:22 AM
    What is your regulatory domain?
  • 4.  RE: Manually configure IAP 275 channel
    Posted Nov 03, 2016 09:33 AM
    Hej Colin,
    The regular domain is "SE"
  • 5.  RE: Manually configure IAP 275 channel
    Posted Nov 05, 2016 06:28 PM
    P- just means that it decreased the power; not that it changed the channel.  INV probably meant that the regulatory domain table (DRT) was not updated for that device, the SE domain until 4.3.0.0
