Manually removing a user from Blacklist
  • 1.  Manually removing a user from Blacklist
    Posted Feb 20, 2017 08:49 AM
    Hi All,
    Controller: 7010
    Version: 6.4.4.9
    I have users that are in the blacklist on my controller and they are set to 10 minutes and then they will be removed. I tried removing them manually before the time is up but it does not allow me to do this.
    I select the mac-address that I want to remove and when I click on "Remove From Blacklist" it does nothing and the mac-address is still in the bllacklist.
    Does anyone know why this is happening and how can this be fixed?
    Kind Regards,
    RIeyaad
  • 2.  RE: Manually removing a user from Blacklist
    Posted Feb 20, 2017 09:11 AM
    You should type "show audit-trail" to see why that is not working.
    You can also try manually removing them from the commandline by using
    (Aruba7005-US) #stm remove-blacklist-client ?
    <client-mac>            client to remove from DoS list
  • 3.  RE: Manually removing a user from Blacklist
    Posted Feb 20, 2017 09:26 AM
    Hi Colin,
    Thanks for the quick response.
    This has work.
    Thank you very much
    Rieyaad
  • 4.  RE: Manually removing a user from Blacklist
    Posted Feb 21, 2017 06:36 AM
    Please try to upgrade to 6.4.4.11.  You could be running into the issue below:
