I believe you need to create an ftp server and download the images for each class of AP and the URL field enters the ftp://<imagepath>. this only option available to you.
thanks
Steve
Steve Spence
Original Message:
Sent: May 05, 2022 04:19 PM
Subject: Manually upgrading Instant IAPs with more than 1 class of AP
Hello All,
I am about to upgrade an aruba instant implementation consisting of Aruba 305's (Ursa) and 505's (Gemini). I usually I upgrade these by going to Maintenance -> Firmware tab and use the automatic upgrade. However I get "image_check_internal error 001 code 2" in response. The only way now is to upgrade via URL. any available aruba http server so as to directly put the appropriate url links on the fields? I've also noticed in areas that have single type deployments, it offers you the ability to browse firmware from you desktop. Is this also an option in this instance?
Devin Gulling
