last person joined: 5 hours ago
Mapping user roles to OU returned from AD
  • 1.  Mapping user roles to OU returned from AD
    Posted Jun 14, 2012 08:34 PM
    When amigopod is integrated with AD is there a way to have it return a different user role based on the OU of the user that has been authenticated?
  • 2.  RE: Mapping user roles to OU returned from AD
    Posted Jun 15, 2012 07:18 AM
    There is a wealth of options available if you are using clearpass (avenda) as a backend which I have integrated with AD, which is what I have done. Connect amigopod to clearpass via radius to make more complex policy decisions. Pass a VSAs back to amigopod. hope this helps?
  • 3.  RE: Mapping user roles to OU returned from AD
    Posted Jun 18, 2012 07:26 AM
    Check the "Advanced Authorization" section of the Amiogopod Exernal Authentication Servers guide.  It has an example (below) of assigning roles based on OUs.   When Amigopod is merged with ClearPass, there are easier and more defined ways of doing this.
    Advanced authorization — Example 1
    This example covers the case where a domain contains several organizational units (OUs), and the
    users in each OU are to be mapped to a specific RADIUS role ID.
    NOTE To determine the appropriate role ID, navigate to RADIUS Services > User Roles and check the
    ID column for the appropriate role.
    For example, to implement the following configuration:
    • OU East should be mapped to RADIUS role ID 4
    • OU Central should be mapped to RADIUS role ID 5
    • OU West should be mapped to RADIUS role ID 6
    Make sure the following configuration is set:
    1. First, ensure that the Base DN for the authentication server is set to the root of the domain –
    for example: DC=amigopod,DC=local – rather than the “users” container. This is necessary as
    the organizational units are located below the top level of the directory and cannot be
    searched from the CN=Users container.
    2. Select the authorization method Use PHP code to assign a user role (Advanced) and use the
    following code:
    if (stripos($user['distinguishedname'],'OU=East')) return 4;
    if (stripos($user['distinguishedname'],'OU=Central')) return 5;
    if (stripos($user['distinguishedname'],'OU=West')) return 6;
    return false;
    Explanation: During user authorization, the distinguished name of the user (which will contain the
    user’s OU) is checked against the defined rules, and an appropriate role ID is returned. If no match
    is found, false is returned, which means that authorization fails and the user’s Access-Request will
    be rejected.
    Advan
  • 4.  RE: Mapping user roles to OU returned from AD
    Posted Jun 19, 2012 02:48 PM
    Ok excellent thank you very much I will go try that and look through the guide.
