Wired Intelligent Edge
MAS 3500 poe disabled, port still has power
  • 1.  MAS 3500 poe disabled, port still has power
    Posted Aug 03, 2015 02:54 PM
    Hello everyone,
    I ran into an issue today and I was hoping some of the veterans would be able to shed light on it.
    I'm in the process of installing some IAP-225s, they are all plugged in (dual homed) but the ports are in shutdown since you need to do things in order so I can configure the virutal controller.
    I'm trying to reboot a few APs via POE cycling but the port still provides power...
    #show interface gigabitethernet 0/0/29
    GE0/0/29 is administratively Down, Link is Down, Line protocol is Down
    Hardware is Gigabit Ethernet, Interface is 2W-C21, Address is 00:1a:1e:16:ba:9f
    Encapsulation ARPA, Loopback not set
    Configured: duplex (N/A), Speed (N/A), FC (Off), Autoneg (Off)
    Auto negotiation in progress
    Interface index: 30
    MTU 1514 bytes
    Link flaps: 24
    Flags: Access, Trusted
    Link status last changed: 0d 00:00:00 ago
    Last update of counters: 0d 00:00:00 ago
    Last clearing of counters: 0d 00:00:00 ago
    Statistics:
    Received 21954831 frames, 1896642034 octets
    0 pps, 0 bps
    11169636 unicast, 704 multicast, 10784491 broadcast
    0 runts, 0 giants, 0 throttles
    0 error octets, 0 CRC frames
    Transmitted 79628884 frames, 5618277482 octets
    0 pps, 0 bps
    68735448 unicast, 66263 multicast, 10827173 broadcast
    0 throttles, 0 errors octets, 0 deferred
    0 collisions, 0 late collisions
    PoE Information:
    Administratively Disable, Port status: Off, Power consumption: 0 mW
    PSE port status: Off, PD detection in progress
    #show interface gigabitethernet 0/0/31
    GE0/0/31 is administratively Down, Link is Down, Line protocol is Down
    Hardware is Gigabit Ethernet, Interface is 2W-C22, Address is 00:1a:1e:16:ba:a1
    Interface index: 32
    MTU 1514 bytes
    Link flaps: 21
    Statistics:
    Received 67201598 frames, 4633811555 octets
    0 pps, 0 bps
    67107346 unicast, 3113 multicast, 91139 broadcast
    Transmitted 34567322 frames, 2889396417 octets
    0 pps, 0 bps
    12993290 unicast, 66678 multicast, 21507354 broadcast
    PoE Information:
    Administratively Disable, Port status: On, Power consumption: 9500 mW
    PSE port status: On
    These are the 2 ports of an IAP-225, and I'm a little confused as to why POE is diabled but the port still provides power.
    Any thoughts?
    (ArubaS3500-48P, Version 7.4.0.1)
    (IAP-225, Version 6.4.2.6-4.1.1.8_50989)
    #AP225
  • 2.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 03:39 AM
    There was related known issue.  Will get back after checking if it is the same as that.
    And also if any fix was made available in any of the higher version images.
    -Vinay
  • 3.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 07:00 AM
    is 'poe-factory-initial' is applied on interfaces. and PoE is disabled under that ?
    Can you try creating your own user defined poe-profile with PoE disabled, And apply that profile to target interfaces ?
  • 4.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 10:02 AM
    No the poe profile isn't poe-factory-initial, I created a new profile for which poe is disabled.
  • 5.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 10:45 AM
    Can you provide below details:
    show interface-config gigabitethernet 0/0/31 | include PoE
    show poe interface gigabitethernet 0/0/31
    show interface-profile poe-profile  <profile-name>
  • 6.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 10:50 AM
    #show interface-config gigabitethernet 0/0/31 | include PoE
    Interface PoE Profile disable gigabitethernet0/0/31
     #show poe interface gigabitethernet 0/0/31
    GE0/0/31: Administratively Disable, Port status: On
    Maximum power: 30000 mW, Power consumption: 9500 mW
    Port voltage: 55700 mV, Port current: 172 mA
    PD class: Class-4, Priority: High, PSE port status: On
     #show interface-profile poe-profile disable
    Power over Ethernet profile "disable" (N/A)
    Parameter Value
    Enable PoE interface Disabled
    Max Power on PoE port milliwatts 30000
    PoE port priority high
    time-range-profile N/A
  • 7.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 04, 2015 01:24 PM
    Yann,
    Config looks fine. Hence, there should not be issue. open a support ticket along with 'tar logs tech-support' for further investgation.
    -Rgds
  • 8.  RE: MAS 3500 poe disabled, port still has power
    Posted Feb 08, 2016 07:05 PM
    Hello Yann,
    Did you find a solution for this problem? I'm experiencing the exact situation. Appreciate it you could share some information.
  • 9.  RE: MAS 3500 poe disabled, port still has power
    Posted Apr 01, 2016 11:46 PM
    I am experiencing this exact problem on a single S2500. I disabled the PoE profile and pushed it out to all of the switches through airwave and this single switch refuses to power off the IAP even though the interface and poe profile both say that it is off.
    Rebooted and power cycled the switch in person, but that didn't help either.
  • 10.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 14, 2016 08:32 PM
    Hi Vincent,
    I had the same issue with MAS running with 7.3 firmware. This seem to be caused by a bug and had been fixed on 7.4 firmware.
  • 11.  RE: MAS 3500 poe disabled, port still has power
    Posted Aug 14, 2016 10:48 PM
    Unfortunately,
       I've been running 7.4 for a long while now and my switches are still having the problem.
