Wired Intelligent Edge
last person joined: 9 hours ago
MAS and vlan 1
  • 1.  MAS and vlan 1
    Posted Oct 23, 2015 02:20 PM
    Has anyone had issue with MAS and vlan 1 with alcatel switches or with another brand?
    we are sending vlan 1, 10,219 from one alcatel switch to an aruba switch and vlan 1 is not working, the other vlans are working just fine.
    we are getting a lot of packet lost like this
    Reply from 192.168.22.74: bytes=32 time=9ms TTL=64
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    The other vlans works fine as i said, but this vlan 1 has this issue..
    Anyone
  • 2.  RE: MAS and vlan 1
    Posted Oct 23, 2015 03:22 PM
    Have not heard of this.  Are all VLANs tagged?  What if another port just has VLAN 1 (access mode) connected to ALcatel. Is the problem still happening?
  • 3.  RE: MAS and vlan 1
    Posted Oct 23, 2015 08:20 PM
    Hello Seth
    Vlan 1 was tagged(i know i need to tagged even if its the native vlan)
    Is not possible to have another port  with just vlan 1, as this swithc is on the second floor, and there is just one cable that connect from the first floor to the second floor.
    As a work around i did this
    On alcatel switch
    vlan 1 as native vlan
    Vlan 220 and 219 tagged
    On aruba switch
    Created vlan 300(which doesnt exist on their network)
    vlan 300 as native vlan
    Vlan 300, 219 and 220 tagged
    So im matching the vlan 300 which is untagged with vlan 1 of alcatel switch which is untagged as well...
    I though that if the problem was that only the VLAND ID i though well lets just change the vlan id but still use the vlan 1 so the client doesnt need to change anything on their network, and it worked...
    Why it doesnt liek vlan id 1 agains the alcatel switch? i dont know....
    I would like to make the vlan 1 works without my work around as i mean their old switch which was a netgear worked just fine with it, how can i tell the client that this doesnt work ona switch that cost like 5  times more than their netgear???
    I know vlan 1 is not recomended, and they should not use it, but i cannot tell the clietn all of the sundden, you need to change your network because this swithces which cost 5 times more does not support that...
    Any ideas??
    Cheers
    Carlos
  • 4.  RE: MAS and vlan 1
    Posted Oct 24, 2015 10:32 AM
    Have not seen this either. Maybe there is some STP activity? What STP is in use? What does "show log system 10" show?
  • 5.  RE: MAS and vlan 1
    Posted Oct 26, 2015 05:33 PM
    The spanning tree mode is PVST
    If i use the default one it doesnt work i mean the mstp(if i use it, then all the vlans has that problems
    time out)
    ping
    Time out
    ping
    and so on.
    If i use PVST just the vlan 1 has that issue...
    I already asked the client to see if he can give me the show you are asking for.
    Cheers
    Carlos
