Wired Intelligent Edge
last person joined: 5 hours ago
MAS Certificate replacement
  • 1.  MAS Certificate replacement
    Posted Jul 27, 2017 10:06 PM
    Hello
    I have a few MAS switches and I am attempting to replace the default certificate following this guide:
    http://www.arubanetworks.com/techdocs/ArubaOS_7_Web_Help/Default.htm#mas_guides/management_access/Managing_Certificates.htm#management_utilities_163792609_1117657
    https://community.arubanetworks.com/t5/Wired-Networks/ArubaOS-Default-Certificate-Revocation-FAQ-Mobility-Access/ta-p/275815
    I have generated the csr, signed it with my internal ca. The doecument doesnt state how to load it into the switch, i am just assuming tftp as I cannot access the webui for some reason which I will troubleshoot after I upgrade it soon.
    I receive the following error when i try to import the signed csr using the following command:
    (edge-sw-01) #crypto pki-import pem ServerCert edgesw01 edgesw01.cer
    Error in importing file
    It is definitley in the flash file system:
    #dir
    -rw-r--r-- 1 root root 1964 Jul 28 01:58 edgesw01.cer
    I have tried as a windows txt and a unix txt (crlf vs lf), same issue.
    it seems i can change the names to anything and the same error appears:
    #crypto pki-import pem ServerCert asd asd
    I have converted the pem to a der and it still doesnt work:
    (edge-sw-01) #crypto pki-import der ServerCert edgesw01 edgesw01.cer
    Error in cert format
    Any ideas?
  • 2.  RE: MAS Certificate replacement
    Posted Aug 06, 2017 09:25 AM
    Updating the code and rebooting seems to have fixed the WebUI which has allowed me to upload a cert via the WebUI.
