Is there a good way to remove all interfaces from an interface group with one command? "apply-to remove all" does not work. You can do "apply-to remove 0/0/0-1/1/1" (ending in 1/1/1 assuming you have 2 stack members) but the command has to be entered twice as it clears the first stack member ports, but leaves behind the second stack member ports. Any thoughts? BTW, this is version 7.3.2.0.
