Wired Intelligent Edge
MAS S2500 not able to be added into Orion/solarwinds
  • 1.  MAS S2500 not able to be added into Orion/solarwinds
    Posted Jan 08, 2014 01:16 PM
    site has 3 stacks of 2500's, 2 of the 3 stacks can be added to Orion but the one stack cant. All snmp configs are identical on the stacks. Orion balks with the following message:
    "Node does not respond with the supplied read/write community string"
    help?
  • 2.  RE: MAS S2500 not able to be added into Orion/solarwinds
    Posted Jan 08, 2014 01:55 PM
    I don't have much expertise on orion, But below are my suggetions
    (You might have already carried below steps, if not try these)
    1. Check any connectivity issue: ping the 3rd stack to see if you have ICMP access
    2. Someties copy and paste of text, could add a "mysterious" space in the string, so it is better to add the strings manually (snmp config)
    3. Network could be running slowly, try increasing the SNMP Timeout.
    4. re-run the configuration wizard
    5. stop & re-start all services & see if problem goes away.
  • 3.  RE: MAS S2500 not able to be added into Orion/solarwinds
    Posted Jan 08, 2014 02:02 PM
    We have all of our MAS stacks in Solarwinds with SNMPv3 credentials.
    Do you have any ACLs on the uplinks either on the stack or upstream that may be blocking management traffic destined for the switch?
  • 4.  RE: MAS S2500 not able to be added into Orion/solarwinds
    Posted Jan 08, 2014 03:32 PM
    drthibod,
    What version of code are you running?
    Best regards,
    Madani
