Wired Intelligent Edge
MAS: Sticky MAC - Phone Isn't Stickied
  • 1.  MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 09:49 AM
    I have a few ports with a phone + computer connected.  These ports have port security enabled, with a mac limit of 2, and sticky MAC.  I've noticed that the computer MAC is stickied, but the phone is not.  The sticky database shows only the computer and, the MACs learned on the port indicate the computer is stickied:
    #show mac-address-table interface gigabitethernet 1/0/17
    Total MAC address: 2
    Learnt: 0, Static: 0, Auth: 0, Phone: 1, Sticky: 1 Blacklisted: 0
    MAC Address Table
    Destination Address Address Type VLAN Destination Port
    xx:xx:xx:xx:xx:xx         Phone  xxx    GE1/0/17
    xx:xx:xx:xx:xx:xx         Sticky xxx    GE1/0/17
    Is this normal?  My concern is that someone could plug in an unmanaged switch and connect  two computers since the phone isn't stickied.
  • 2.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 09:54 AM
    Is this a trusted or untrusted interface?
  • 3.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Trusted.
  • 4.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 10:01 AM
    Hm. I assume the phone is in a voice vlan separate from the client device? I wonder if its not being stickied because it is technically in a different VLAN and sticky is determined at the VLAN level, not port.
  • 5.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Thecompnerd,
    I suspect you are using "voip-mode auto-discover". Is that correct? If so, there is currently an issue with Sticky MAC and auto-discover that we are working to resolve. Auto-Discover only needs to be enabled if you are using CDP only phones. If you are using LLDP-MED phones, do not enable this knob and sticky-MAC will work as expected.
    Best regards,
    Madani
    *** Corrected my poor grammer... typed too quickly this morning.
  • 6.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 10:12 AM
    Yes, auto-discover is enabled on the voip profile.  They're LLDP, so if I disable this feature will that resolve the issue?
  • 7.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 10:14 AM
    Tim,
    Yes, different VLANs.  I'd expect sticky to MAC to work at the port level just like it does on a Cisco switch.
  • 8.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 10:21 AM
    Yes, change the voip-mode to "voip-mode static" and it should work.
    Best regards,
    Madani
  • 9.  RE: MAS: Sticky MAC - Phone Isn't Stickied
    Posted Feb 27, 2014 10:35 AM
    Thanks Madani!
