mass client dropping from wireless
  • 1.  mass client dropping from wireless
    Posted Mar 14, 2014 11:32 AM
    I am getting walkups reporting that people are dropping off of wireless, and when I go into airwave I see that the client count has dropped by 50%. There are 5 SSIDs being serviced, all of which are connected to vlans with no wired ports. The client count usually comes back with no intervention on my part. Where can I look to see why this is happening?
    Russell
  • 2.  RE: mass client dropping from wireless
    Posted Mar 14, 2014 12:55 PM
    Can you pick a client that you know if dropping and turn up some logging? Also, this seems like a major issue so you should open a TAC case in parallel.
    logging level debugging user-debug <mac-address>
    logging level debugging arm-user-debug <mac address>
  • 3.  RE: mass client dropping from wireless
    Posted Mar 14, 2014 03:34 PM
    alright, what do I look for in the logs?
    Russell
  • 4.  RE: mass client dropping from wireless
    Posted Mar 14, 2014 05:21 PM
    Make sure your APs are not bootstrapping
    Show ap debug counters , look for high bootstrapping numbers
    Check your connection from the controller to your Uplink switch and confirm that there's a lot of errors
    Does it happen at certain times of day when there's a lot of users ?
    You have a lot SSIDs on your environment , you may want to turn on drop multicast / broadcast
    What version of AOS you have installed and type APs ?
  • 5.  RE: mass client dropping from wireless
    Posted Mar 17, 2014 08:53 AM
    what are high bootstrap numbers? I see double digits in half of my APs, single in the other half. Nothing over 32. No errors on the uplink. APs are all 135s. multicast/broadcast dropping is turned on on all SSIDs.
    Russell
