Master and Standby/Master Redundancy
  • 1.  Master and Standby/Master Redundancy
    Posted Jul 16, 2017 05:15 PM
    I have a question to find out the best way to setup the controllers.
    There is two master controller in the Branch. I have configured them as Master and Standby master controllers with VRRP and Master Redendancy. AP failover fine between controllers.
    LMS IP is pointing towards VRRP address.
    I have seen also HA Group configuraiton as a sample. I am just wondering,
    - What is the Major difference between Master Redendancy and HA group in this setup?
    - Do I have to configure them both? or which on is Aruba approved configuration?
    Lateron I would like to add a Controller in Data centre so if both controller fails then AP should go and connect to data centre controller.
    What would be the best approach for this? Having 3 rd LMS IP?
    Please guide me.
    Nilay.
  • 2.  RE: Master and Standby/Master Redundancy
    Posted Jul 16, 2017 11:03 PM
    HA is not necessary with master redundancy.  Just make the LMS-IP the VRRP.
    If you want to extend the redundancy to the datacenter, just make the  LMS-IP the VRRP and backup LMS-IP the ip address of the datacenter controller.
    That is how you can configure for redundancy on a basic level.
    HA configuration would provide additional scenarios detailed here:  http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/VRRP/HighAvOverView.htm%3FTocPath%3DArubaOS%2520User%2520Guide%2520Topics%7CVirtual%2520Router%2520Redundancy%2520Protocol%2520(VRRP)%7C_____1
