Master-Backup Redundancy
  • 1.  Master-Backup Redundancy
    Posted Aug 20, 2014 02:38 PM
    Hi All,
    Can I configure a Master controller and 2 Backup Master controllers?
    The Idea is:
    - if the Master fail, the 1st Backup Master become Master.
    - If the Master fail and the 1st Backup Master fail, the 2sd Backup Master become Master.
    I read something about Cluster of Master Controllers, but I`m not sure if it will works that way.
    Ed
  • 2.  RE: Master-Backup Redundancy
    Posted Aug 20, 2014 02:56 PM
    You won't be able to achieve this using the master-redundancy method.
    But you accomplish this using the HA setup but HA is only supported on AOS 6.3 and up
  • 3.  RE: Master-Backup Redundancy
    Posted Aug 20, 2014 03:30 PM
    Thank you Seth and Victor.
    I will try a Master Redundancy and HA setup working toguether. (look picture attached).
    Controller 1 : 172.16.0.1
    Controller 2: 172.16.0.2
    Controller 3: 172.16.0.3
    VRRP: 172.16.0.4
  • 4.  RE: Master-Backup Redundancy
    Posted Aug 20, 2014 04:49 PM
    Keep in my mind that .3 won't be able to see the local db sync since this only happen between controllers in the master-redundancy setup
  • 5.  RE: Master-Backup Redundancy
    Are you trying to achieve AP redundancy?  I would recommend AP fast failover for that.
    For Master redundancy, you are limited to 2 controllers.
