Master-Backup - Unable to add localip
  • 1.  Master-Backup - Unable to add localip
    MVP EXPERT
    Posted Nov 27, 2015 12:48 PM
     Hi all, I was wondering if you could help with the following. We have an Master - Master Backup deployment with a local controller which points to the VRRP address on the Master controllers.
    However in the event of a failover to the back master, I don’t think the local controller will be able to connect to the backup-master since this parameter is not in there.
    Basically don’t seem to have the option to add a localip to the backup-master.  Not sure if that is expected behaviour. ?
    Current version is Aruba OS 6.4.2.5
  • 2.  RE: Master-Backup - Unable to add localip
    Posted Nov 27, 2015 01:12 PM
    The localip parameter on the master or the local?
  • 3.  RE: Master-Backup - Unable to add localip
    MVP EXPERT
    Posted Nov 28, 2015 03:06 AM
    Hey on the backup master. Thanks
  • 4.  RE: Master-Backup - Unable to add localip
    Posted Nov 28, 2015 04:07 AM
    Do you have a screenshot of that?   On every master controller, you should be able to configure the localip for each local controller that would connect:
    (host) (config) #localip 0.0.0.0 ipsec gw1234xyz
    On every local controller, you should be able to configure the master controller that the local controller would connect to:
    (host) (config) #masterip 10.1.1.250 ipsec gw1234567
    Are you saying that the localip command is not available on the backup master?  It should be...
