Master controller AP database not updating
  • 1.  Master controller AP database not updating
    Posted Jul 25, 2012 07:57 AM
    - In my environment i have a master controller and 7 local controllers.
    -  I have run into an issue where the master controller ap database shows access points to be in group A when they are really in group Z (as reported by the local controller ap database).
    - The master controller also reports a specific AP to be down where as the local controller reports this AP to be up.
    - If I select an AP on the master to reprovision, it has the correct group A selected by default already.
    I seem to be having this issue with only 1 of the local controllers. Configurations are synched.
    Any tips on where I can look to troubleshoot this issue?
    Matt
  • 2.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 08:18 AM
    What version of ArubaOS is this?  Are all controllers on this version?
  • 3.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 10:55 AM
    The master and all local controllers are running 6.1.3.0_32142
    ~Matt
  • 4.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 11:01 AM
    How many APs are on the local controllers and how many SSIDs are in use on each AP?
  • 5.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 01:15 PM
    Depending on where the AP is there will be 2 or 3 SSIDs on the access point.  The affected groups only have 2 SSIDs.
    master
    Total AP Licenses : 648
    AP Licenses Used : 17
    LOCAL 1 -- the one with the issue
    Total AP Licenses : 512
    AP Licenses Used : 198
    LOCAL 2
    Total AP Licenses : 640
    AP Licenses Used : 399
    LOCAL 3
    AP Licenses Used : 105
    LOCAL 4
    AP Licenses Used : 227
    LOCAL 5
    AP Licenses Used : 387
    LOCAL 6
    AP Licenses Used : 194
    LOCAL 7
    AP Licenses Used : 401
  • 6.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 02:25 PM
    You are under the published limits for the master (assuming it's an M3), so you shouldn't be seeing scalability issues.  I can't say for sure it will fix it, but 6.1.3.3 has a TON of resolved issues, so it might be worth upgrading.  If the problem persists, a TAC case would be the next step.
    OR.. you can open a TAC case now and see if they can either fix the issue or give you a definitive answer whether 6.1.3.3 will address this issue.
  • 7.  RE: Master controller AP database not updating
    Posted Jul 25, 2012 02:42 PM
    Thanks for the advice.
