last person joined: 3 hours ago
Master Controller Redundancy across multiple data centres
  • 1.  Master Controller Redundancy across multiple data centres
    Posted Apr 30, 2013 12:12 PM
    The Aruba design guides recommend VRRP or LMS between controller pairs for failover.
    I am hoping to split my local and master controller pairs across two data centres. The LMS feature will allow me to failover between the local WLCs because it is a layer 3 process.
    The design guides only recommend using VRRP for the master controller pair. This is slightly challenging across multiple data centres due to the layer 2 link required. What is the best way to achieve master controller failover? You could configure a layer 2 tunnel between the data centres but I am hoping there is a simpler way.
  • 2.  RE: Master Controller Redundancy across multiple data centres
    Posted Apr 30, 2013 12:41 PM
     I think that if you have layer 3 setup between master you will need to setup a GRE tunnel
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1308
  • 3.  RE: Master Controller Redundancy across multiple data centres
  • 4.  RE: Master Controller Redundancy across multiple data centres
    Posted May 01, 2013 11:27 AM
    Thank you - the GRE looks like the answer
