Config: 7240 as Master controller and 3 7220 as local controller, every local with 1000 APs. is the 2K limit relevant for the master/local config?
Each controller should only be running at 80% capacity, maximum.
There are no issues with the 7240 as master in your current situation. The limit for the 7240 only applies if that controller is actually terminating APs.
