Master IAP is not responding to SNMP polling with Solarwinds monitoring
  • 1.  Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 24, 2014 02:32 AM
    In our enviroment, we are using solarwinds for monitoring network devices. We have IAP configured in few sites, which is configured with SNMP for monitoring the health and ports. But Master IAP are not respoding to SNMP in solarwinds, but other IAP in the same site are responding wihout any issues. We have configured snmp-server and snmp-server community string as well.
    ArubaOS (MODEL: 135), Version 6.2.1.0-3.4.0.2
    Any suggestions?
    Thank you.
    #AP135
  • 2.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 24, 2014 07:51 AM
    Do you have SW pointed to the virtual controller IP or the actual APs address?
  • 3.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 24, 2014 08:42 AM
    We have the AP IP configured in SW.
    Jayanth P L
    Phone: 9566099108/9444888899
  • 4.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 26, 2014 09:23 PM
    If you want this to work, you must upgrade to IAP 4.1.
    SNMP is fixed in that release.
    See this thread
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/SNMPWALKing-the-VC-does-not-always-respond/td-p/91112/highlight/true
  • 5.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 27, 2014 02:23 AM
    Hi Pasquale Monardo,
    Thanks for your reply. U mean to say needs to upgrade from version 6.2.1.0-3.4.0.2 to Version 6.2.1.0-4.1.
    Please clarify so that i can propose to my higher official to get an approval.
    Thank you.
  • 6.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 27, 2014 07:16 AM
    Yes, you must upgrade to 6.4.0.2-4.1.0.0.
    If you have IAP-93's, you must wait for 4.1.0.1 because 4.1.0.0 will not work with IAP-93s as per the release notes.
    What model do you have?
  • 7.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jun 29, 2014 10:14 PM
    We have AP-135 in our environment. Let me suggest the same and come back to you if any further assistance required.
    Thank you,
    Jay
  • 8.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jul 02, 2014 12:29 PM
    Have you had a chance to clarify?
  • 9.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jul 02, 2014 11:02 PM
    Yes we got a plan to do the firmware upgrade. Will get back to you once done.
    Thank you.
    Jay
  • 10.  RE: Master IAP is not responding to SNMP polling with Solarwinds monitoring
    Posted Jul 28, 2014 11:01 PM
    Hi All,
    After upgrading the IAP firmware version, the master IAP and other IAPs are responding to SNMP without any issue.
    Thank you for suggestions.
    Jay
