  • 1.  Master IP
    Posted Jun 03, 2014 03:28 AM
    I need to migrate RAPs onto a new controller which happens to be a local. If I provision the RAPs with a "master IP address" of the local controller will the RAPs have any issues if the device is not actually a master.
  • 2.  RE: Master IP
    MVP
    Posted Jun 03, 2014 05:06 AM
    You can terminate remote AP's to a local controller without any problems.
  • 3.  RE: Master IP
    Posted Jun 03, 2014 05:47 AM
    Thank you.
  • 4.  RE: Master IP
    Posted Jun 03, 2014 06:01 AM
    The masterip just tells the AP where to go initially to get their configuration.  If there is no lms-ip in the config sending the ap to a different controller, they will stay on that masterip.
