  • 1.  master-local
    Posted Feb 19, 2016 05:04 AM
    Hello all
    i wanna make master local in my office, but why master and local must in one vlan? is the possible to create master local in different vlan?
    rgrds
  • 2.  RE: master-local
    Posted Feb 19, 2016 05:40 AM
    Yes. It's recommended.
    Sent from Nine
  • 3.  RE: master-local
    Posted Feb 19, 2016 08:46 AM
    hi all but i got the problem when i put master n local in different vlan :
    master : vlan 50 : 10.10.50.4/24
    local  : vlan 100 : 10.10.100.1/24
    and when i look in local controller the master is unreachable
    i think i set it up correctly, like ipsec key. but still in master when i check #show switches, still no local controller.
    but when i put local controller in same vlan with master everything looks smoothly.
    what i missed?
  • 4.  RE: master-local
    Posted Feb 19, 2016 07:47 AM
    Only the master and standby controllers have to be on the same vlan. But master and local just needs a layer 3 connectivity.
    Rajaguru Vincent
  • 5.  RE: master-local
    Posted Feb 19, 2016 09:17 AM
    Can you ping both default gateways for each VLAN from both controllers
    Sent from Outlook for iPhone
  • 6.  RE: master-local
    Posted Feb 19, 2016 09:30 AM
    i set the network, so yeah no problem with network or firewall here the log :
    logging level debugging system process cfgm
    show log system 50 (master)
  • 7.  RE: master-local
    Posted Feb 19, 2016 10:27 AM
    Clear all the Master-Local configs from both the controllers. You can verify it by running "show run | include masterip" on local. And "show run | include localip" on master.
    Once the configs are cleared, reboot the local controller so that the ipsec map will go away.
    Then check if the master and local controllers are able to ping each other. If there is any confusion with VLAN, it's better to ping by specifiying the source VLAN.
    If the connectivity is fine, rebuild the master-local. If that doesn't fix, raise a TAC case for troubleshooting further.
    Rajaguru Vincent
  • 8.  RE: master-local
    Posted Feb 19, 2016 10:38 AM
    ok vincent i'll do it on monday and i will post it again here, but mean while is there any problem with master-local running on aruba 7005 both? OS 6.4.2.15
  • 9.  RE: master-local
    Posted Feb 19, 2016 11:04 AM
    I believe there are no master-local issues seen so far with 6.4.2.15 on 70xx controllers.
    Rajaguru Vincent
  • 10.  RE: master-local
    Posted Feb 23, 2016 01:01 AM
    Hello all, hope you good today.
    i have able to built master-local in L3 network finnaly, but can you guys show me how to giving vlan in wlan profile at the local controller? because the apply button like disabled, i dont think i should do it on master controller because the vlan for client wlan its no there. appreciate for any help guys
  • 11.  RE: master-local
    Posted Feb 23, 2016 01:22 AM
    You would use named VLANs.
    See here:
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-a-named
    -VLAN-and-how-do-I-configure-it/ta-p/181562
  • 12.  RE: master-local
    Posted Feb 23, 2016 01:37 AM
    thank you so much, its solve now
  • 13.  RE: master-local
    Posted Feb 19, 2016 09:38 AM
  • 14.  RE: master-local
    Posted Feb 19, 2016 10:29 AM
    would you like to show me the step? because i've tried the regural way and no luck.
    i really apreciate it, colin or anyone?
