master local controller exporting local-userdb-ap
  • 1.  master local controller exporting local-userdb-ap
    Posted Oct 04, 2012 12:45 PM
    I have a load of RAP's whitelisted on the master controller and i was wondering how you export the local-userdb-ap list from the master controller so that i can import it onto the local controller?
  • 2.  RE: master local controller exporting local-userdb-ap
    Posted Oct 04, 2012 12:55 PM
    Whitelisted APs are a table in the local user database.  When you export the local user database, the whitelist is included.
    Unfortunately, when you import them into a new controller, your local database users will be replaced in the import, as well..
  • 3.  RE: master local controller exporting local-userdb-ap
    Posted Oct 04, 2012 12:59 PM
    thanks for that. I thought you had to export the local-userdb-ap, but it wouldn't let me.
    regards
    Pete
  • 4.  RE: master local controller exporting local-userdb-ap
    Posted Feb 11, 2013 10:20 AM
    Colin,
    If I already imported a local-userdb-ap from one controllerA , will that one be replace if I import a local-userdb from controllerB
  • 5.  RE: master local controller exporting local-userdb-ap
    Posted Feb 12, 2013 08:14 AM
    Importing the local-userdb from one controller into another overwrites that controllers local-userdb from what I have experienced.
  • 6.  RE: master local controller exporting local-userdb-ap
    Posted Feb 12, 2013 08:16 AM
    Thanks for the respond, I did tested it yesterday and did noticed that
