Master - Local topology "disconnected" when activating Site-To-Site
  • 1.  Master - Local topology "disconnected" when activating Site-To-Site
    Posted Oct 26, 2016 01:11 AM
    I am facing an issue when configuring and connecting Site-to-Site between master-local controller.
    All controller has been configured with VPN S2S, and tests run as exptected. Private client from A can ping/rdp to client on B.
    The problem is, the "master-local" connection shown  disconnected, when I enable S2S VPN. On master monitoring page, local controller and APs are down.
    Spoiler
    CONTROLLER MASTER
    Aruba 7210
    Aruba OS 6.4.4.9
    CONTROLLER LOCAL
    ARUBA 7210
    ARUBA OS 6.4.4.9
    MASTER S2S CONFIG
    crypto-local isakmp key [********] fqdn-any
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto-local ipsec-map dyn-sts 100
      set ikev1-policy 0
      peer-ip 0.0.0.0
      peer-fqdn fqdn-id 100
      vlan 0
      src-net 192.168.0.0 255.255.255.0
      dst-net 192.168.101.0 255.255.255.0
      set transform-set "default-transform"
      pre-connect disable
     factory-cert-auth disable
      trusted enable
      uplink-failover disable
      ip-compression disable
      force-natt enable
    LOCAL S2S CONFIG
    crypto-local isakmp key [*******] address [pbl.ip.mastr] netmask 255.255.255.255
      set ikev1-policy 0
      peer-ip [pbl.ip.mastr]
      local-fqdn 100
      vlan 100
      src-net 192.168.101.0 255.255.255.0
      dst-net 192.168.0.0 255.255.255.0
      pre-connect enable
      trusted enable
      force-natt enable
    (LOCAL) #show crypto isakmp sa
    ISAKMP SA Active Session Information
    Initiator IP     Responder IP   Flags       Start Time      Private IP
    192.168.100.254  [pbl.ip.mastr] i-a-p     Oct 26 11:00:39          -
    (LOCAL) #show crypto ipsec sa
    IPSEC SA Active Session Information
    Initiator IP     Responder IP     InitiatorID         ResponderID         Flags    Start Time      Inner IP
    192.168.100.254  [pbl.ip.mastr]   192.168.101.0/24    192.168.0.0/24      UT     Oct 26 10:49:36     -
    (MASTER) # show crypto isakmp sa
    [pbl.ip.lcl]    172.16.0.2     r-a-p     Oct 26 11:10:41          -
    (MASTER) #show crypto ipsec sa
    [pbl.ip.lcl]    172.16.0.2       192.168.101.0/24    192.168.0.0/24      UT     Oct 26 10:59:38     -
    is it possible to set S2S between master-local, without breaking "the" master-local connection?
    Yopianus Linga
  • 2.  RE: Master - Local topology "disconnected" when activating Site-To-Site
    Posted Oct 26, 2016 05:24 AM
    By default, a master/local has a site to site VPN already setup.  Why not reuse that connection for traffic?  Type "show ip route" to see what routes are available.  You can then write a route for whatever network you want to traverse over the ipsec connection.
  • 3.  RE: Master - Local topology "disconnected" when activating Site-To-Site
    Posted Oct 26, 2016 11:52 AM
    Hi Colin,
    I have checked the ip route output and there were only local controller that has ip route to "default-local-master-ipsec" listed; while on master controller, no ip route defined using ipsec.
    Master has static public IP address while local is dynamic address.
    On local, i have set static route to master-local-subnet thru IPSEC and it connected, but not the other way around.
    On master, do I have to defined local controller using its public ip?
    here are the output of both controller regarding IPSEC-MAP.
    Spoiler
    (MASTER) #show crypto-local ipsec-map
    Crypto Map Template"default-local-master-ipsecmap" 9999
         IKE Version: 1
         IKEv1 Policy: All
         Security association lifetime seconds : [300 -86400]
         Security association lifetime kilobytes: N/A
         PFS (Y/N): N
         Transform sets={ default-ml-transform }
         Peer gateway: 0.0.0.0
         Interface: VLAN 0
         Source network: 0.0.0.0/0.0.0.0
         Destination network: 0.0.0.0/0.0.0.0
         Pre-Connect (Y/N): N
         Tunnel Trusted (Y/N): Y
         Forced NAT-T (Y/N): N
         Uplink Failover (Y/N): N
         IP Compression (Y/N): Y
    (MASTER) #
    (MASTER) #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
           M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 172.16.0.1 to network 0.0.0.0 at cost 1
    S*    0.0.0.0/0  [1/0] via 172.16.0.1*
    ------> no ipsec
    (MASTER) #
    (LOCAL) #show crypto-local ipsec-map
         IKE Version: 1
         IKEv1 Policy: All
         PFS (Y/N): N
         Peer gateway: [pbl.ip.mastr]
         Interface: VLAN 0
         Source network: 192.168.100.254/255.255.255.255
         Destination network: 192.168.10.1/255.255.255.255
         Pre-Connect (Y/N): Y
    (LOCAL) #
    (LOCAL) #show ip route
    Gateway of last resort is 192.168.100.1 to network 0.0.0.0 at cost 10
    S*    0.0.0.0/0  [10/0] via 192.168.100.1*
    S    192.168.0.0/24 [1/0] ipsec map default-local-master-ipsecmap  --> the default ipsec
    C    192.168.10.1/32 is an ipsec map default-local-master-ipsecmap --> new ip route through ipsec
    (LOCAL) #
    Yopianus Linga
