Master Redundancy don't Synchronize
  • 1.  Master Redundancy don't Synchronize
    Posted Aug 20, 2014 09:30 PM
    I have configured a Master Redundancy on 7200 controllers using lab 15 documention of the boot camb course.
    One of them now is a master and the other is backup under the redunadency tab.
    when I turn off the Master the backup one change to Master automaically,
    under Monitoring tab the master has network information while the backup not.
    Under controller information the first is Master while the second is Stand-by
    But under WLAN Controllers: I can see only one controller on each not 2
    When I shut down the Master all APs become down, I also found that none of the configuration on the Master one (IPs, VLANs, Groups, ......) has been syncronized with the backup one.
    What should be the problem ????
  • 2.  RE: Master Redundancy don't Synchronize
    Posted Aug 20, 2014 09:53 PM
    Please look at your VRRP ?
    show vrrp status
    Are you pointing all your APs to the VRRP VIP ?
    Also please look at the show master-redundancy
  • 3.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 06:49 AM
    i just pointed one AP  to VRRP VIP, but it goes down when the Master is down
    VRRP for Master "172.10.100.254"
    Virtual Router 100:
    Description primary‐master
    Admin State UP, VR State MASTER
    IP Address 172.10.100.253, MAC Address 00:00:5e:00:01:64, vlan 1
    Priority 110, Advertisement 1 sec, Preemption Enable Delay 0
    Auth type PASSWORD, Auth data: ********
    tracking type is master-up-time, duration 30 minutes, value 20
    tracked priority 130
    VRRP for Backup "172.10.101.254"
    Virtual Router 100:
    Description backup‐master
    Admin State UP, VR State BACKUP
    Priority 100, Advertisement 1 sec, Preemption Enable Delay 0
    tracked priority 100
    VRRP for new virtual IP "172.10.100.253"
    Virtual Router 100:
    show master-redundancy for Master "172.10.100.254"
    Master redundancy configuration:
    VRRP Id 100 current state is MASTER
    Peer's IP Address is 172.10.101.254
    Peer's IPSEC Key is ********
    show master-redundancy for Backup "172.10.101.254"
    VRRP Id 100 current state is BACKUP
    Peer's IP Address is 172.10.100.254
    show master-redundancy for new virtual IP "172.10.100.253"
  • 4.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 07:34 AM
    I tried show database synchronize, and recieved the following
    Last manual synchronization time: Thu Aug 21 13:27:40 2014
    To Master Switch at 172.10.101.254: *** FAILED ***
    WMS Database backup file size: 0 bytes
    Local User Database backup file size: 0 bytes
    CPSec Database backup file size: 0 bytes
    Synchronization took 30 second
    Last failure cause: Standby switch did not respond to the start request or is not ready
    1 synchronization attempted
    1 synchronization have failed
    Periodic synchronization is enabled and runs every 20 minutes
    Synchronization doesn't include Captive Portal Custom data
  • 5.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 07:36 AM
    Make sure the ipsec key matches
  • 6.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 08:02 AM
    They are the same, and still failed
  • 7.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 09:47 AM
    Try 'show datapath tunnel table' for IPsec tunnel between them.
  • 8.  RE: Master Redundancy don't Synchronize
    Posted Aug 21, 2014 09:49 AM
    Also 'show network log 50' to see if the VRRP is flagging any issues.
