Master Redundancy Failure
  • 1.  Master Redundancy Failure
    Posted Jun 18, 2019 07:55 AM
    We are getting an error on the master redundancy syncronization as shown below:
    Last L2 synchronization time: Tue Jun 18 15:31:30 2019
    Last L3 synchronization time: Secondary not synchronized since last reboot
    To Master Switch at 192.168.23.3: *** FAILED ***
    WMS Database backup file size: 53377 bytes
    Local User Database backup file size: 46496 bytes
    Global AP Database backup file size: 0 bytes
    IAP Database backup file size: 0 bytes
    Airgroup Database backup file size: 0 bytes
    License Database backup file size: 0 bytes
    CPSec Database backup file size: 0 bytes
    Bocmgr Database backup file size: 0 bytes
    L2 Synchronization took 7 second
    L3 Synchronization took less than one second
    Last failure cause: Standby switch did not acknowledge the user database restore request
    423 L2 synchronization attempted
    423 L2 synchronization have failed
    0 L3 synchronization attempted
    0 L3 synchronization have failed
    L2 Periodic synchronization is enabled and runs every 30 minutes
    L3 Periodic synchronization is disabled
    I have logged into the CLI on the master switch and done show switches:
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    192.168.23.2 None WLAN-Cont-Primary Building1.floor1 standalone OAW-4010 8.3.0.0_64659 up UPDATE SUCCESSFUL 0 4
    192.168.23.3 None WLAN-Cont-Secondary Building1.floor1 standby OAW-4010 8.3.0.5_68279 up UPDATE SUCCESSFUL 10 4
    Synchronization doesn't include Captive Portal Custom data
    Not sure as to why this is happening have had no problems before.  Both switches are also showing in the GUI under the mobility master node.
  • 2.  RE: Master Redundancy Failure
    Posted Jun 18, 2019 09:24 AM
    Hi As per above log it's one of member is having 8.3.0.5 and primary one have 8.3.0.0.
    Can you check both version are same or any members has been rebooted with another AOS?
    And give some cli commands to check in detail.
  • 3.  RE: Master Redundancy Failure
    Posted Jun 18, 2019 09:25 AM
    Yes I have advised my colleague to do this tonight as it can't be upgraded in hours.
    Just didn't know if this would cause a sync issue however? Do you think it would?
  • 4.  RE: Master Redundancy Failure
    Posted Jun 18, 2019 11:00 AM
    Yes. As per AOS MM-Redundancy, both versions should be the same.
    otherwise, sync issue. Just try with the same version on backup and check status as per database sync time.
    Note: and also check MM redundancy can enable only on MM level only.
    Best Regards,
    Sureshredy
