Master - Standby issue with synchronizing Radius server key
  • 1.  Master - Standby issue with synchronizing Radius server key
    Posted Oct 28, 2015 10:39 AM
    Hi to all,
    I have a issue with synchronizing radius server key from master to local WLC.
    Basically all config is synchronized but key on WLC2 for Radius server is Changeme:
    #show aaa authentication-server radius server-radius
    RADIUS Server "server-radius"
    Parameter                              Value
    Host                                   10.0.252.36
    Key                                    Changeme
    Key can not be changed/added on WLC2 as it is Master-Standby configuration. I tried to save configuration/wr mem on WLC1 but key stayed the same.
     #show switches
    All Switches
    IP Address   Name         Location  Type    Version         Status  Configuration State  Config Sync Time (sec)  Config ID
    10.20.132.8  wlc1  1IFC.20F  master  6.1.3.13_43996  up      UPDATE SUCCESSFUL    0                       1016
    10.20.132.7  wlc2  1IFC.20F  local   6.1.3.13_43996  up      UPDATE SUCCESSFUL    9                       1016
    Is there any special command to trigger synchronization of Radius servers or what should be next step in troubleshooting?
    Thanks in advance.
  • 2.  RE: Master - Standby issue with synchronizing Radius server key
    Posted Dec 20, 2015 06:37 AM
    did you ever figure this one out? i can't really think of anything expect a restart of something like that. i don't know of any extra sync command or such.
    did it really not work btw? were requests from that local denied by the radius server?
    which ArubaOS version are you running?
    else there is always support to contact.
  • 3.  RE: Master - Standby issue with synchronizing Radius server key
    Posted Dec 20, 2015 07:00 AM
    Have you tried to remove and readd, or create a new one?
  • 4.  RE: Master - Standby issue with synchronizing Radius server key
    Posted Dec 21, 2015 05:07 AM
    Hi to all,
    Aruba adviced to use command:
    cfgm set sync-type complete
    It was on: ArubaOS (MODEL: Aruba6000), Version 6.1.3.13
    This helped and radius server configuration has synched right away. Everything else was working also.
    Hoping this will help somebody else.
    Peter
  • 5.  RE: Master - Standby issue with synchronizing Radius server key
    Posted Dec 21, 2015 03:39 PM
