Master to Local VPN
  • 1.  Master to Local VPN
    Posted Oct 20, 2015 12:12 PM
    Hi Guys,
    Hope you are doing well!!
    I have a Master controller and would like to expand my network by adding a remote Local controller. The Master controller is behind a Firewall and a router (it is actually on the LAN), I would like to know what are the ports that I should open and redirect on the Firewall to allow the Master-Local communication.
    I saw some documentation about the ports to be opened (UDP 4500) and wanted to ask you guys if you have ever deployed such architecture and can help with this information
    Many thanks in advance!
  • 2.  RE: Master to Local VPN
    Posted Oct 20, 2015 12:57 PM
    UDP 4500 should be all you need to build the IPSec tunnel between the controllers .
    Are you trying to send traffic through the IPSec tunnel ?
