Master/Local access points
  • 1.  Master/Local access points
    Posted Mar 12, 2014 07:49 AM
    This is likley to be a very stupid question but I am going to ask it anyhow...
    I am setting up 4 controllers, one master and 3 locals running 6.3.1.2
    The "issue" I have is that on the master a "show ap database" shows all the access points and which controller they are connected to (a snapshot of this output);
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    6c:f3:7f:cc:51:e1 HUB1 105 192.168.210.28 Up 23h:34m:11s 2 192.168.201.12 0.0.0.0
    6c:f3:7f:cc:51:f0 HUB10 105 192.168.216.20 Up 40m:4s 2 192.168.201.14 0.0.0.0
    6c:f3:7f:cc:92:7c HUB4 105 192.168.213.22 Up 22h:46m:55s 2 192.168.201.13 0.0.0.0
    and a show ap database off one of the locals;
    AP Database
    6c:f3:7f:cc:51:f0 HUB10 105 192.168.216.20 Up 44m:44s 2I 192.168.201.14 0.0.0.0
    6c:f3:7f:cc:51:f6 HUB10 105 192.168.216.17 Up 44m:44s 2I 192.168.201.14 0.0.0.0
    6c:f3:7f:cc:51:f7 HUB10 105 192.168.216.18 Up 44m:44s 2I 192.168.201.14 0.0.0.0
    6c:f3:7f:cc:92:72 HUB8 105 192.168.215.21 Up 10h:50m:58s 2I 192.168.201.14 0.0.0.0
    6c:f3:7f:cc:93:8d HUB8 105 192.168.215.22 Up 10h:50m:58s 2I 192.168.201.14 0.0.0.0
    but a "show ap active" on all the controllers state that there are 0 ap's.
    Does the flag 2I on the local have anything to do with this as the I indicates that the ap is Inactive?
    I am remote at the moment so cant actually check if the SSID's are active.
    I dont know if this is normal having never setup a master/local before :smileyembarrassed:
    thanks
    Andy
  • 2.  RE: Master/Local access points
    Posted Mar 12, 2014 08:10 AM
    Loaded 6.3.1.3 and I can now see the access points, but dont know if the code or the reboot sorted it :/
  • 3.  RE: Master/Local access points
    Posted Mar 12, 2014 06:56 PM
    It looks that they are IKE2 (so CPSec is enabled) and they are inactive due to misconfiguration, lack of the group or VLAN. Please go to Web and at the AP Provisioning under the AP list you have the legend of all the codes.
    HTH
  • 4.  RE: Master/Local access points
    Posted Mar 13, 2014 03:02 AM
    Hi
    CPSec is enabled and I am sure the config was right as it all has been working since the reboot.
    Cheers
    Andy
