Master/Local Controller
  • 1.  Master/Local Controller
    Posted Jan 19, 2014 05:54 PM
    In Master/Local Architecture , Can local controller contiue to operate as normal if master fails ?
  • 2.  RE: Master/Local Controller
    Posted Jan 19, 2014 06:02 PM
    Ye, the local will be able to function but the master is needed for the following :
    - push config
    - arm calculations
    - ids/ips
  • 3.  RE: Master/Local Controller
    Posted Jan 19, 2014 10:14 PM
    Yes
    All the APs termintating on the local controller will keep working
    The thing is that you wont be able to modify ap configurations or any configuration that the master syncronize with the  local controller.
    Cheers
    Carlos
  • 4.  RE: Master/Local Controller
    Posted Jan 20, 2014 01:45 AM
    Something else to keep in mind, is that the local-user/ap databases are master only, so if you're making use of these, the local might run in a reduced service state during failover (i.e. certain configurations wouldn't work fully). Examples are...
    1. If you're using machine-auth enforcement.
    2. Using the local databases for guest or RAP authentication.
    I did have it in my mind a new feature was mentioned regarding syncing local databases from masters to locals, but maybe I imagined/dreamt it?!?!
    Thanks.
  • 5.  RE: Master/Local Controller
    Posted Jan 20, 2014 05:59 AM
    Yes iLocal will still works, but take note not to reboot the local controller when your Master fails.
    Gordon
  • 6.  RE: Master/Local Controller
    Posted Jan 21, 2014 01:47 AM
    Masters are responsible for the following functions in the WLAN:
    1. Policy configuration
    2. AP white lists
    3. Wireless security coordination
    4. Valid AP list
    5. RF visualization
    6. Location
    7. Initial AP configuration
    8. Control plane security
    9. Authentication and roles
    Locals are responsible for the following functions in the WLAN
    1. AP, AM, and SM configuration, management, and software updates
    2. Device session termination
    3. ARM assignments and load balancing
    4. RFProtect™ security enforcement and blacklisting:
    5. RFProtect spectrum analysis
    6. CPsec AP certification
    7. Mobility
    8. Quality of service (QoS)
