Master/Local - LMS and Backup-LMS - High Availibility ?
  • 1.  Master/Local - LMS and Backup-LMS - High Availibility ?
    Posted Sep 05, 2014 03:53 AM
    Hi Guys,
    i didn't find a thread 100% fitting to my problem, so i opened a new thread.
    I have two 7030 Controllers in the HQ. One is configured as master controller, the other one is configured as local controller, so that i can terminate 128 APs. Master-Redundancy wouldn't work because i could only terminate 64 APs then, but I still need to terminate 70 APs. So i need to do this scenario. I knew, that in case of a controller failure some APs are going to be lost.
    Now my problem:
    If I reboot the Local-Controller, where some APs are terminating, they do not change to the Master-Controller. Is that per Design?
    Here is the environment:
    Master-Controller:
    Controller-IP: VLAN 10 / 192.168.10.1 / 255.255.255.0
    Management-IP: VLAN 77 / 192.168.77.1 / 255.255.255.0
    Loca-Controller:
    Controller-IP: VLAN 10 / 192.168.10.2 / 255.255.255.0
    Management-IP: VLAN 77 / 192.168.77.2 / 255.255.255.0
    The Access Points are booting in VLAN 10 and get an IP-Addres in the same subnet where the both controller are.
    The Local-Controller has an configured Master-IP-Address of 192.168.77.1, maybe is here the problem? Should it be 192.168.10.1 (same subnet)?
    Here is the output of the AP database:
    AP-1
    IP: 192.168.10.11
    Group: Campus-AP
    AP-Type: 205
    Flags: 2
    Switch-IP: 192.168.10.2
    Standby-IP: 0.0.0.0
    In the AP System Profile I configured both Controllers as LMS and Backup-LMS.
    As you can see, the Backup-LMS is still 0.0.0.0. So the AP doesnt change the controller in case of failure of the Local-Controller.
    Thomas
  • 2.  RE: Master/Local - LMS and Backup-LMS - High Availibility ?
    Posted Sep 05, 2014 04:30 AM
    Okay, I found a solution.
    I changed the Master-IP on the Local-Controller, so that it is 192.168.10.1 (same L2-VLAN). I updated the HA-Group, and put both Controllers with the DUAL-Role inside the HA-Group.
    There is still no Standby-IP in the AP database, but the AP can failover (with 4-6 seconds downtime, but thats okay. The IPSec-Tunnel of Control Plane Security maybe has to reestablish first, and need his time. After 600 seconds the AP do the failover back to the Local-Controller.
    Everything fine now.
    Thomas
  • 3.  RE: Master/Local - LMS and Backup-LMS - High Availibility ?
    Posted Sep 05, 2014 04:36 AM
    the standby IP is related to the HA fast failover feature. it wont be different when you use backup LMS-IP.
    who is your LMS configuration exactly? could you post a screenshot of the AP profile?
    [edit] you were faster yourself, thanks for reporting back.
