matching Aruba controllers with APs
  • 1.  matching Aruba controllers with APs
    Posted Nov 12, 2021 05:35 AM
    Hey there! I'm in the discovery phase of replacing my home Ruckus network with Aruba and need some help. I'm looking at the AP-225 APs which can be had really cheap online but require a controller. I found the S1500-24P for a pretty fair price as well and am wondering if this has the controller software to be compatible with these APs?
    Another thought: Would I be able to connect an IAP-225 to my network and then connect multiple AP-225 APs into that one since the ISP model has a controller built-in?
    The IAP models cost double the AP models and I'm trying to do this replacement affordably.
    Thanks!
    Jillian Corvus
  • 2.  RE: matching Aruba controllers with APs
    MVP GURU
    Posted Nov 12, 2021 01:01 PM
    The S1500-24P can not act as a controller. If you only have AP-225s and not IAP-225s then you will definetly need a controller, or virtual controller to manage them.
    AP-225s can not join a cluster of IAP-225s.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
