Cloud Managed Networks
last person joined: 9 hours ago
Matching multiple templates
  • 1.  Matching multiple templates
    Posted May 04, 2020 07:23 AM
    I have googled and tried to go through the posts here to no avail.
    I'm curious how Aruba central handles when multiple templates match a device in a template group. For instance if I create a temple that matches "all" models, then create a couple of other templates that match two specific models, but "all" part names, and then create yet another template for specific parts (and so on, similar setups with the other variable matching parameters), how will Central handle this?
    Will it only pick the best match, the first match (if so in which order will it go through the templates), all matches, etc?
    Thanks in advance.
