Maverick Connection Issues
  • 1.  Maverick Connection Issues
    Posted Feb 04, 2014 06:50 PM
    Good Afternoon,
    I have a fully patched iMAC 10.9.1 (M that I am trying to get connected to my Controller.  WPA2 enterprise.  I have two other fully patched MACs that are working just fine, they are not the same hardware though (MB Pro, Air)  windows, ios and android are just fine
    It connects just fine to my unsecured SSID, but not to the WPA2  I was connected and connecting fine before I upgraded to 6.3.1.2
    what are some troubleshooting steps that I can take?
  • 2.  RE: Maverick Connection Issues
    Posted Feb 04, 2014 07:03 PM
    Please run these commands :
    show  auth-tracebuf | include <mac address> - You will be able to see the EAP process
    Enable logging level debugging security process authmgr abd run the show log security all | include <device mac>
    What are you using for RADIUS ?
  • 3.  RE: Maverick Connection Issues
    Posted Feb 04, 2014 07:12 PM
    We are using Windows 2008 r2 for the RADIUS.
    here is a little more information:
    When we upgraded to the new firware on the controller, we also replaces our AP125 with an AP225.  I physically moved the iMAC to a location with an AP125 that is beyond the reach of the AP225.  I can connect just fine to our WPA2 SSIDs now.  Did some reboots and shutdowns (which was killing the connection when trying to connect to the AP225)
    very strange
  • 4.  RE: Maverick Connection Issues
    Posted Feb 04, 2014 07:19 PM
    Here is the output
    Feb 4 14:28:44 :132030: <ERRS> |authmgr| Dropping EAPOL packet sent by Station d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10
    Feb 4 15:09:12 :126065: <WARN> |wms| |ids| AP(9c:1c:12:94:0e:10@Wolverton-Conf): Valid Client Not Using Encryption: An AP detected an unencrypted frame between a valid client (d4:9a:20:54:d0:a0) and access point (BSSID 9c:1c:12:94:0e:11), with source d4:9a:20:54:d0:a0 and receiver 00:1b:ed:16:5a:00. SNR value is 0.
    Feb 4 15:26:31 :126065: <WARN> |wms| |ids| AP(9c:1c:12:94:0e:10@Wolverton-Conf): Valid Client Not Using Encryption: An AP detected an unencrypted frame between a valid client (d4:9a:20:54:d0:a0) and access point (BSSID 9c:1c:12:94:0e:11), with source d4:9a:20:54:d0:a0 and receiver ff:ff:ff:ff:ff:ff. SNR value is 46.
    Feb 4 15:34:00 :132030: <ERRS> |authmgr| Dropping EAPOL packet sent by Station d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10
    Feb 4 15:59:11 :132030: <ERRS> |authmgr| Dropping EAPOL packet sent by Station d4:9a:20:54:d0:a0 00:24:6c:ba:f4:d0
    Feb 4 16:00:59 :126065: <WARN> |wms| |ids| AP(00:24:6c:ba:f4:d0@KERN-721): Valid Client Not Using Encryption: An AP detected an unencrypted frame between a valid client (d4:9a:20:54:d0:a0) and access point (BSSID 00:24:6c:ba:f4:d1), with source d4:9a:20:54:d0:a0 and receiver 00:1b:ed:16:5a:00. SNR value is 40.
    Feb 4 16:03:02 :132030: <ERRS> |authmgr| Dropping EAPOL packet sent by Station d4:9a:20:54:d0:a0 00:24:6c:ba:f4:d0
    Feb 4 16:04:28 :132030: <ERRS> |authmgr| Dropping EAPOL packet sent by Station d4:9a:20:54:d0:a0 00:24:6c:ba:f4:d0
  • 5.  RE: Maverick Connection Issues
    Posted Feb 04, 2014 10:58 PM
    Can you provide the show  auth-tracebuf | include <mac address> output as well?
  • 6.  RE: Maverick Connection Issues
    Posted Feb 05, 2014 10:36 AM
    When I run that command, with or without the "| include <mac>" there is no output
  • 7.  RE: Maverick Connection Issues
    Posted Feb 05, 2014 11:52 AM
    Did you enable debugging for that Mac?
    (controller-config) # logging level debug user-debug <mac>
  • 8.  RE: Maverick Connection Issues
    Posted Feb 05, 2014 12:56 PM
    ah, I did not do that.  I did now.  here is the output
    Feb 5 09:54:09 station-up * d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 - - wpa2 aes
    Feb 5 09:54:09 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 1 5
    Feb 5 09:54:09 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 - -
    Feb 5 09:54:14 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 - -
    Feb 5 09:54:14 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 1 5
    Feb 5 09:54:19 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 - -
    Feb 5 09:54:19 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 2 5
    Feb 5 09:54:24 station-down * d4:9a:20:54:d0:a0 9c:1c:12:94:0e:12 - -
    Feb 5 09:54:48 station-up * d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 - - wpa2 aes
    Feb 5 09:54:48 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 1 5
    Feb 5 09:54:49 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 - -
    Feb 5 09:54:49 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 1 5
    Feb 5 09:54:53 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 - -
    Feb 5 09:54:53 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 1 5
    Feb 5 09:54:59 eap-start -> d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 - -
    Feb 5 09:54:59 eap-id-req <- d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 2 5
    Feb 5 09:55:04 station-down * d4:9a:20:54:d0:a0 9c:1c:12:94:0e:10 - -
  • 9.  RE: Maverick Connection Issues
    Posted Feb 05, 2014 02:42 PM
    It looks like the device is not responding to the EAP ID request (Provides the username/password) , please try the following uninstall the Certificate previously installed
    1. Start Finder.
    2. From the Go drop-down list, select Utilities.
    3. Double-click the Keychain Access icon.
    And find the cert and delete it then remove the ssid from the preferred wireless networks and then reboot .
    Try again and run the same commands.
    What AP are you connecting at this point ? AP125 or AP225 ?
  • 10.  RE: Maverick Connection Issues
    Posted Feb 06, 2014 03:38 PM
    Right now I am only working with the AP 225 at it seems to be limited to the AP 225.  Deleting the key for the ssid worked one time.  I deleted it, removed the ssid from the prefered networks and rebooted.
    It connected on the first try. So I turned the Wi-Fi on the iMAC off, waited a few seconds and turned it back on again.  It went back to the same thing.
    It almost seems like the AP 225 is holding onto something or there is something screwy with how the iMAC is doing the wi-fi
    I have attached the tracebuff commands
    Attachment(s)
    txt
    tracebuff.txt   7 KB 1 version
