I am seeing some strange behavior with respect to the limitation on the SSID profile of Max Client Associations. I currently have it set to the default value of 64 but in some cases, I am seeing far more than that on a single radio. I do see logs pointing to what I believe are association failures due to this default limit but it doesn't seem to be across the board.
Log: Assoc failure: a4:b8:05:8a:bd:4a: AP 10.50.88.167-00:24:6c:33:e3:cb-lew-103 Reason AP is resource constrained-Max Clients Associated.
Attached an imaged grabbed from AMP showing an instance where there are more associations than should be allowed. I did a search for the same log message from above for this AP and found nothing..
Any help in understanding this would be great. I know in some cases I will need to up that Max Association value but I need to know that the system is abiding by it in the first place..
