max mac entries for mac authentication
  • 1.  max mac entries for mac authentication
    Posted Jan 07, 2022 09:31 AM
    For the 500 series which is the max?
    It used to be 256 for IAP 92/93 and 512 for the rest
    But with the new models? for example the 500 series? it would be 512? or its more?
    Cheers
    Carlos
  • 2.  RE: max mac entries for mac authentication
    Posted Jan 07, 2022 11:22 AM
    For the internal auth server on the IAP? (affects not just mac auth, but any local authentication)
    I'm not finding anything indicating that it has been increased over 512 with newer Instant firmware, but will continue to check.
