Max Nu of AP managed by IAP
  • 1.  Max Nu of AP managed by IAP
    Posted Jan 17, 2014 12:27 PM
    What is the Max Nu of AP managed by IAP  ( Virtual Controller ) ?
    Can IAP-105 Manage   group of IAP-105 & IAP-93 ?  & Vice Versa ?
  • 2.  RE: Max Nu of AP managed by IAP
    Posted Jan 17, 2014 12:33 PM
    Theoretically, with 105, my understanding is there is no limit in the AP software.
    With the 93, the last time I looked, you should have no more than 16? Perhaps somebody has newer info than me on this though?
  • 3.  RE: Max Nu of AP managed by IAP
    Posted Jan 17, 2014 01:35 PM
    the.racking.mo.. is correct.  No limit on the number of IAPs in a group except for the IAP-9x. The IAP-9x is still limited to 16 in one group.  Further, if you introduce a single IAP-9x into a group of IAP-105s that whole group will be limited to 16.
  • 4.  RE: Max Nu of AP managed by IAP
    Posted Jan 21, 2014 11:40 AM
    I had an actual deployment with the same senarios and due to the IAP93's limitation it was running on 16 IAPs only. Way out is to seperate the IAP105s into 1 subnet and IAP93s into another subnet.
