Max number of AP's (515) Aruba Cental on a single site?
  • 1.  Max number of AP's (515) Aruba Cental on a single site?
    Posted Jun 08, 2020 07:00 AM
    I'm looking at replacing my current wireless system and one vendor has recommend 515's using Aruba central , we have approx 105 access points but I'm concerned this may too many and we should go down the controller route?
    Struggling to find any good information on the limits that aren't forum posts.
  • 2.  RE: Max number of AP's (515) Aruba Cental on a single site?
    Posted Jun 08, 2020 07:13 AM
    In regards to Aruba central management , I don’t think there’s a limit , the limit is tied to amount of APs you are planning to deploy using the same L2 management VLAN or same L2 Cluster
    That recommended limit is 125
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Max number of AP's (515) Aruba Cental on a single site?
    Posted Jun 08, 2020 10:52 AM
    In addition to Victor's response, what's the anticipated client count for the location?
  • 4.  RE: Max number of AP's (515) Aruba Cental on a single site?
    Posted Jun 09, 2020 08:06 AM
    Number of users on the site is approx 2000 but concurrent wifi devices is nearer the 600 mark.
