Maximum access points that can be synchronized/provision in Aruba Central
  • 1.  Maximum access points that can be synchronized/provision in Aruba Central
    Posted May 02, 2017 01:53 AM
    Good day! what is the maximum number of access points that can be synced in Aruba Central? How can I sync/provision our 54 access points?
  • 2.  RE: Maximum access points that can be synchronized/provision in Aruba Central
    Posted May 02, 2017 04:15 AM
    Since the subscription is per device, I dont see a reason if it cant be done. You only need to make sure you have active subscription to support required number of devices.
  • 3.  RE: Maximum access points that can be synchronized/provision in Aruba Central
    Posted May 04, 2017 10:54 AM
    Hi Emerson,
    Are all the IAP's part of same cluster?
    The best way of getting them on Central is to first add them in the cluster.
    Then you can add the master IAP from the cluster on Central using cloud activation key.
    This should automatically pull up the devices in to your account.
