Maximum transmit power and transmit power per chain
  • 1.  Maximum transmit power and transmit power per chain
    Posted May 25, 2017 11:40 AM
    Hi there,
    I am checking the IAP-325 datasheet and I see the following:
    • Maximum (aggregate, conducted total) transmit power
    (limited by local regulatory requirements):
    --2.4 GHz band: +24 dBm (18 dBm per chain)
    --5 GHz band: +24 dBm (18 dBm per chain)
    This IAP is a 4x4 MIMO, so it has 4 transmit chains. If each one has 18 dBm transmit power, it would have a maximum transmit power of 18+18+18+18 = 72 dBm, which is a huge power and doesn't match that of the datasheet which is 24 dBm. What am I doing wrong?
    Julián
  • 2.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 11:49 AM
  • 3.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 12:04 PM
    Not clear :(
    I will look for more sources.
    Julián
  • 4.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 12:08 PM
    It is complicated and quite frankly can be further restricted by regulatory requirements.  It is easier to see the maximum power on each channel by running the command "show ap allowed-max-eirp" to see the real number:   http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/show ap allowed_max_EIRP.htm?Highlight=allowed
  • 5.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 12:36 PM
    Yes, I already know that power will be restricted by the regulatory domain where the IAP resides in. Where I am confused is with the relation between the max transmit power and the transmit power per chain, but I didn't know is so complicated.
    By the way, thanks for the link with all that information about Instant, I didn't know about it. It's great!
    Julián
  • 6.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 01:21 PM
    The indoor maximum power does not really vary that much between channels.  It is almost not worth understanding the calculations..
  • 7.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 02:29 PM
    18dBm is 63mW (10^1.8). You ca sum the linear power numbers (in mW), so in total you have 4x 63 = 252mW. Expressed in dBm that is 24dBm (10*log(252)).
    4x corrsponds with +6dB.
  • 8.  RE: Maximum transmit power and transmit power per chain
    Posted May 25, 2017 04:29 PM
    Hi Onno,
    Great explanation here and in the other posts! Completely understood.
    Julián
  • 9.  RE: Maximum transmit power and transmit power per chain
    Posted Sep 09, 2017 09:55 AM
    Hi Onno and Colin,
    One more doubt about this. When you modify the output power on an AP, for example an Instant AP within the ARM section, do you modify the aggregate transmit power or the per chain transmit power?
  • 10.  RE: Maximum transmit power and transmit power per chain
    Posted Sep 11, 2017 10:01 AM
    Hi there,
    Any idea? I guess it is the aggregate transmit power, I would just like to confirm.
  • 11.  RE: Maximum transmit power and transmit power per chain
    Posted Sep 11, 2017 10:44 AM
    It's the total / aggregate (if you want to call it that). So if you set 20dB as the EIRP, that will be the radio + antenna = 20
  • 12.  RE: Maximum transmit power and transmit power per chain
    Posted Sep 11, 2017 11:03 AM
    OK Jerrod, many thanks for confirming!
