Maximum VPN Pool
  • 1.  Maximum VPN Pool
    Posted Jun 16, 2014 01:21 PM
    Hi All
    I have a Controller 3200. When I try to create a new VPN pool, I receive the messagem below:
    Error executing Command ip local pool "BC_Pool" "192.168.171.200" "192.168.171.220":Reached the maximum number of pools configurable
    The Controller has a limit to create VPN pools?
    Best Regards.
    #3200
  • 2.  RE: Maximum VPN Pool
    Posted Jun 16, 2014 03:14 PM
    10 may be the max.   Isthat your 11th pool?    If so, do you need more than 10?  Can you extend the ranges of any?
  • 3.  RE: Maximum VPN Pool
    Posted Jun 17, 2014 10:21 AM
    Yes, I need more than 10. Maybe 15.
    Can I extend this limit, for example, using a second Controller?
    Best Regards.
