Wired Intelligent Edge
Maximum VRF instance of Aruba & HPE Switches
  • 1.  Maximum VRF instance of Aruba & HPE Switches
    Posted Nov 20, 2023 05:05 AM
    Hi Guys,
    Im unable to find maximum no of VRF instances support in ArubaOS-CX switches and HPE comware series switches
    I already referred to the Data Sheets, Aruba Switch feature navigator but its not clearly indicate
    Anyone can help me to find Maximum VRF instance count for Aruba & Comware switches
  • 2.  RE: Maximum VRF instance of Aruba & HPE Switches
    MVP EXPERT
    Posted Nov 20, 2023 05:36 AM
    I had a quick look at the Datasheet for the 6300 and this shows the maximum VRFs (256) is it possible you are looking at an old Datasheet?
  • 3.  RE: Maximum VRF instance of Aruba & HPE Switches
    Posted Dec 01, 2023 05:26 AM
    You can look these values up in the Aruba Switching Feature Navigator. Enable the scaling slider to get the scaling numbers.
    This just is for the Aruba switches, ArubaOS Switch and AOS-CX.
