last person joined: 7 hours ago
MC 7210 poor health
  • 1.  MC 7210 poor health
    Posted Oct 15, 2022 05:22 PM
    hi gents,
    I am running a two node cluster of 7210 on 8.6.0.17 with 250 access points.
    Each controllers is connected with one interface to a data center switch.
    But one controllers is on poor health saying: "Controller has at least one uplink with poor health".
    Looking on the switch interface everything is looking fine at my pov.
    How is poor health for one uplink defined? What needs to happen on an interface to get rated as poor?
    I just updated from 8.6.0.9 to 8.6.0.17 but nothing changed.
    Looking at the mobility conductor dashboard, it says no client is connected to the controller with poor health but 177 are connected to the one with good health. Is that normal or are the clients getting connected to the good controller because the other one is on poor health?
  • 2.  RE: MC 7210 poor health
    Posted Oct 15, 2022 07:23 PM
    Go on the commandline of one controller and type "show lc-cluster group-membership" and see if it sees the other controller.
  • 3.  RE: MC 7210 poor health
    Posted Oct 16, 2022 01:54 AM
    on first with poor health:
    (lzarubamc1) *#show lc-cluster group-membership
    Cluster Enabled, Profile Name = "lzcluster"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 20%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 50
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    peer 192.168.96.53 128 L3-Connected CONNECTED (Member, last HBT_RSP 65ms ago, RTD = 0.508 ms)
    self 192.168.96.52 128 N/A CONNECTED (Leader)
    and on the second:
    (lzarubamc2) *#show lc-cluster group-membership
    Redundancy Mode On
    Cluster Info Table
    self 192.168.96.53 128 N/A CONNECTED (Member)
    peer 192.168.96.52 128 L3-Connected CONNECTED (Leader, last HBT_RSP 39ms ago, RTD = 0.000 ms)
  • 4.  RE: MC 7210 poor health
    Posted Oct 16, 2022 07:49 AM
    This is your problem: peer 192.168.96.53 128 L3-Connected CONNECTED
    There is probably a client VLAN that is not connected between the clusters in your controller and you need to either (1) exclude the VLAN from the cluster profile or (2) make sure the controllers can see each other on that VLAN.
    Use the command " show lc-cluster vlan-probe status" to find out which VLAN that is.  L3-Connected means that your cluster doesn't have a proper failover functionality.
  • 5.  RE: MC 7210 poor health
    Posted Oct 17, 2022 06:20 AM
    Okay, I fixed that and now I have L2-connected on both controllers but at the GUI controller 1 is still on poor health.
    (arubamc1) *#show lc-cluster vlan-probe status
    Cluster VLAN Probe Status
    Type IPv4 Address REQ-SENT REQ-FAIL ACK-SENT ACK-FAIL REQ-RCVD ACK-RCVD VLAN_FAIL CONN-TYPE START/STOP
    peer 192.168.96.53 27784 0 5 0 5 13 0 L2 Conn 3/ 3
    (arubamc2) *#show lc-cluster vlan-probe status
    peer 192.168.96.52 27773 0 13 0 13 5 0 L2 Conn 2/ 2
  • 6.  RE: MC 7210 poor health
    Posted Oct 17, 2022 11:35 AM
    Please see if you can drill down using this article:  https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=b04a34e1-4410-4993-98b0-ece2375a8888
  • 7.  RE: MC 7210 poor health
    Posted Oct 18, 2022 03:50 AM
    Problem solved.
    There was a WAN Uplink configured with no connection. Who ever did that in the past..
    After deleting health is good now.
  • 8.  RE: MC 7210 poor health
    Posted Oct 17, 2022 11:25 AM
    Hi, have you defined a lacp port-channel and ended up using just 1 cable (like you metion)?
    If you have a 2-port lacp defined and only 1 cable connected, the controller may tell you poor healt.
    I hope this helps
