  • 1.  MCM in AOS8
    Posted Dec 28, 2017 10:03 PM
    Hi All,
    May I check with regards to the term MCM in AOS8
    MCM = Mobility Controller Master – referenced in the migration tool to migrate to a non-MM Mobility Controller Master
    Does this have to be of 72xx series or any hardware controller can be a MCM?
  • 2.  RE: MCM in AOS8
    Posted Dec 28, 2017 10:43 PM
    You can use a 7030 or any 72xx controller as your MCM , keep in mind that you can’t terminate APs on the MCM
    Get Outlook for iOS
