MD Config failure
  • 1.  MD Config failure
    Posted May 07, 2020 09:50 AM
    Hi Friends,
    One of the MD controller is showing the config failure.
    Please let me know how to make it to a good config.
    Below are the logs from the MD.
    (HCAINNOI16F02DMZWLC02) #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.112.60.248 None HCAINNOI16F02DMZWLC02 Building1.floor1 MD Aruba7030 8.3.0.7_70587 up CONFIG FAILURE(1985) 10 1985
    Total Switches:1
    (HCAINNOI16F02DMZWLC02) #show configuration failure all
    All Configuration Failure
    IP Address MAC Config ID Process Command Message
    10.112.60.248 00:0b:86:b6:87:77 1985 Layer2/3 switchport mode trunk Illegal Operation: Interface belongs to a port-channel group
    (HCAINNOI16F02DMZWLC02) #show running-config | begin "port-channel 6"
    Building Configuration...
    interface port-channel 6
    add gigabitethernet 0/0/1
    add gigabitethernet 0/0/3
    trusted
    trusted vlan 1-4094
    switchport access vlan 500
    (HCAINNOI16F02DMZWLC02) #show port status
    Port Status
    Slot-Port PortType AdminState OperState PoE Trusted SpanningTree PortMode Speed Duplex PortError
    0/0/0 GE Enabled Down N/A Yes Disabled Access Auto Auto -
    0/0/1 GE Enabled Up N/A N/A N/A PC6 1 Gbps Full -
    0/0/2 GE Enabled Down N/A No Disabled Access Auto Auto -
    0/0/3 GE Enabled Down N/A N/A N/A PC6 Auto Auto -
    0/0/4 GE Enabled Down N/A No Disabled Access Auto Auto -
    0/0/5 GE Enabled Down N/A No Disabled Access Auto Auto -
    0/0/6 GE Enabled Down N/A No Disabled Access Auto Auto -
    0/0/7 GE Enabled Down N/A Yes Disabled Trunk Auto Auto -
    (HCAINNOI16F02DMZWLC02) #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP
    vlan 500 10.112.60.248 / 255.255.255.128 up up
    vlan 1 unassigned / unassigned up down
    vlan 572 unassigned / unassigned up down
    vlan 573 unassigned / unassigned up down
    vlan 574 unassigned / unassigned up down
    loopback unassigned / unassigned up up
    Mallikarjun
    Attachment(s)
    txt
    MD config failure.txt   3 KB 1 version
  • 2.  RE: MD Config failure
    Posted May 07, 2020 12:04 PM
    Share the config on each individual interface that is part of the channel-group
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: MD Config failure
    Posted May 11, 2020 10:26 AM
    Hi Victor,
    Thank you for the quick response.
    Please find the port configurations of ports which are part of port-channel.
    interface gigabitethernet 0/0/1
    trusted vlan 1-4094
    no poe
    interface gigabitethernet 0/0/3
    trusted
    trusted vlan 1-4094
    no poe
    Mallikarjun
