md reboot automatically
  • 1.  md reboot automatically
    Posted Jun 12, 2021 08:50 AM
    hi all
         i have MM(8.5.0.13)+4 MD, 2MD(8.5.0.13) is one cluster01,other 2 md(8.5.0.8) is one cluster02;At 5 o'clock this morning, one of the md reboots automatically,is 8.5.0.13,log:Reboot Cause: Unknown reboot reason (238:238:2) (Intent:cause:register ee:ee:50:2)
    leo ma
  • 2.  RE: md reboot automatically
    MVP GURU
    Posted Jun 13, 2021 08:25 AM
    I would grab the crash logs off of the devices that rebooted and open a TAC case. If you see a * added to the cli prompt that means there is a crash file available for export. Use "tar crash" to create the crash files and save them to flash. Then copy them off of the devices.
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: md reboot automatically
    Posted Jun 13, 2021 11:29 AM
    hi
       no crash,but tac view global case have same  this  log:Reboot Cause: Unknown reboot reason (238:238:2) (Intent:cause:register ee:ee:50:2) ,
    leo ma
