mdns airgroup problem - mDNS proxy runtime error
  • 1.  mdns airgroup problem - mDNS proxy runtime error
    Posted Oct 14, 2022 11:51 AM
    Hi
    I'm troubleshooting an issue where Bonjour/mDNS clients, particularly printers, automatically rename themselves because they think that there's another device on the network with the same name.
    I have confirmed that there are no loops on the network (Aruba 2530s with loop-protect active on all switches and ports) and there are certainly no client devices with duplicate names.
    The network setup is very simple. It's a small flat network with the one wireless SSID dropping wireless clients onto the same broadcast domain as the wired devices. The SSID settings are pretty much the default with ARP broadcast filtering enabled. Airgroup is on with the following settings:
    airplay     Enabled   _airplay._tcp          AirPlay
                          _raop._tcp
                          _appletv-v2._tcp
    airprint    Enabled   _ipp._tcp              AirPrint
                          _pdl-datastream._tcp
                          _printer._tcp
                          _scanner._tcp
                          _http._tcp
                          _http-alt._tcp
                          _ipp-tls._tcp
                          _fax-ipp._tcp
                          _riousbprint._tcp
                          _ica-networking._tcp
                          _ptp._tcp
                          _canon-bjnp1._tcp
                          _ipps._tcp
                          _ica-networking2._tcp
    itunes      Disabled  _home-sharing._tcp     iTunes
                          _apple-mobdev._tcp
                          _daap._tcp
                          _dacp._tcp
    remotemgmt  Enabled   _ssh._tcp              Remote management
                          _sftp-ssh._tcp
                          _ftp._tcp
                          _telnet._tcp
                          _rfb._tcp
                          _net-assistant._tcp
    sharing     Disabled  _odisk._tcp            Sharing
                          _afpovertcp._tcp
                          _xgrid._tcp
    googlecast  Disabled  _googlecast._tcp       GoogleCast supported by Chromecast etc
    AmazonTV    Disabled  _amzn-wplay._tcp       Amazon fire tv
    Possibly related is this entry, constantly repeated, when I 'show log system' on an AP:
    Oct 14 16:48:07  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: xxx-MB-B\.RUSTAGE._ssh._tcp.local^IIN^ISRV 0 0 22 xxx-MB-BRUSTAGE-3.local ; ttl=120 too large; doesn't fit in bulk resp !
    Oct 14 16:48:08  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: US-Foyer-Photocopier._ipp._tcp.local^IIN^ITXT "txtvers=1" "qtotal=1" "rp=ipp/print" "pdl=application/postscript,image/urf,application/pdf,image/jpeg" "product=(RICOH MP C4503 PS3)" "ty=RICOH MP C4503" "note=ground-Floor" "PaperMax=<legal-A4" "priority=3
    Oct 14 16:48:08  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: Deputy\032Head-\032DL._printer._tcp.local^IIN^ITXT "txtvers=1" "qtotal=4" "rp=AUTO" "pdl=application/postscript,application/vnd.hp-PCL,application/vnd.hp-PCLXL,text/plain" "ty=HP LaserJet P2055dn" "product=(HP LaserJet P2055dn)" "priority=51" "adminurl=
    Oct 14 16:48:09  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: xxx-MB-B\.RUSTAGE._ssh._tcp.local^IIN^ISRV 0 0 22 xxx-MB-BRUSTAGE-3.local ; ttl=120 too large; doesn't fit in bulk resp !
    Oct 14 16:48:10  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: US-Foyer-Photocopier._ipp._tcp.local^IIN^ITXT "txtvers=1" "qtotal=1" "rp=ipp/print" "pdl=application/postscript,image/urf,application/pdf,image/jpeg" "product=(RICOH MP C4503 PS3)" "ty=RICOH MP C4503" "note=ground-Floor" "PaperMax=<legal-A4" "priority=3
    Oct 14 16:48:10  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: Deputy\032Head-\032DL._printer._tcp.local^IIN^ITXT "txtvers=1" "qtotal=4" "rp=AUTO" "pdl=application/postscript,application/vnd.hp-PCL,application/vnd.hp-PCLXL,text/plain" "ty=HP LaserJet P2055dn" "product=(HP LaserJet P2055dn)" "priority=51" "adminurl=
    Oct 14 16:48:11  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: xxx-MB-B\.RUSTAGE._ssh._tcp.local^IIN^ISRV 0 0 22 xxx-MB-BRUSTAGE-3.local ; ttl=120 too large; doesn't fit in bulk resp !
    Oct 14 16:48:12  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: US-Foyer-Photocopier._ipp._tcp.local^IIN^ITXT "txtvers=1" "qtotal=1" "rp=ipp/print" "pdl=application/postscript,image/urf,application/pdf,image/jpeg" "product=(RICOH MP C4503 PS3)" "ty=RICOH MP C4503" "note=ground-Floor" "PaperMax=<legal-A4" "priority=3
    Oct 14 16:48:12  mdns[3768]: <343001> <ERRS> |AP US-3F-ICTRoom@192.168.10.40 mdns|  4149071872 mDNS proxy runtime error at mdns_build_pkt_rec_list 74 RR: Deputy\032Head-\032DL._printer._tcp.local^IIN^ITXT "txtvers=1" "qtotal=4" "rp=AUTO" "pdl=application/postscript,application/vnd.hp-PCL,application/vnd.hp-PCLXL,text/plain" "ty=HP LaserJet P2055dn" "product=(HP LaserJet P2055dn)" "priority=51" "adminurl=
    The problem is, the issue is sporadic and doesn't seem to be reproducible and so makes it more difficult to troubleshoot.
    Any suggestions very much welcomed.
    Thank you
  • 2.  RE: mdns airgroup problem - mDNS proxy runtime error
    Posted Oct 20, 2022 07:00 AM
    Hi sram,
    AirGroup is particularly useful when you have zero configuration services that you would like to be accessible across multiple VLANs. In your case it sounds like all of your devices are within the same broadcast domain so the question is, is AirGroup actually required in your situation?
    https://www.arubanetworks.com/techdocs/Instant_811_WebHelp/Content/instant-ug/services/airgroup/conf-airgroup.htm
    AirGroup Deployment Guide
  • 3.  RE: mdns airgroup problem - mDNS proxy runtime error
    Posted Oct 20, 2022 07:11 AM
    Thank you for taking the time to reply. You raise a valid point and I came to this conclusion last week. I have actually now turned off Airgroup completely but of course it was required when the broadcast filtering was set to its default value of ARP. I have also now disabled broadcast filtering meaning that the APs are simply bridging wireless to wired hence all mDNS services on the wired lan are now available on the wireless and vice versa. Things appear to have stabilised and so I think we're ok for now.
    We have suggested the implementation of at least one VLAN along with an Aruba CX 6200 to handle the inter-vlan routing. Then we will of course need to re-enable ARP filtering and configure airgroup.
    One thing I struggled with was finding a clear recommendation (or VRD) of how to handle broadcast filtering and airgroup on a flat network. The assumption seems to be that any SSID created will operated on a different VLAN. After this experience I now believe that having the default ARP filtering enabled along with Airgroup configured on a flat network is detrimental and can cause the problems I experienced.
    Appreciate any thoughts from those more knowledgeable in these areas.
    Thank you again
