MDPS Issue with iOS
  • 1.  MDPS Issue with iOS
    Posted Mar 15, 2012 12:25 AM
    Hi All,
    I was recently completing a demo of Amigopod and ran into trouble with the MDPS function.
    I setup pretty much everything as per default settings and created Wi-Fi and provisioining profiles however when i complete the login and profile download to the IOS device, when i click install i am prompted with an error saying " Could not connect to the server"
    The MDPS logs show the following as the last entry.
    MDPS Access [id/1/4]: Phase 1 - Send Profile Service
    Client:    172.27.152.4:51613
    App User:
    Script:    /mdps_profile.php
    Function:  Phase1_SendProfileService
    Arguments: (
      'method' => 'GET',
      'scheme' => 'http',
      'host' => '172.27.151.62',
      'port' => '80',
      'uri' => '/mdps_profile.php/id/1/4',
    I'm thinking that this is probably just a config error however thought i'd throw it out to the forum before i hassle the TAC.
    Scott
  • 2.  RE: MDPS Issue with iOS
    Posted Mar 15, 2012 01:09 AM
    Scott,
    Was your demo setup on an Open SSID by any chance. You might be hitting the challenge of iOS automatically trying to detect the presence of a captive portal enabled network and displayed a mini browser or web sheet. This is known as the Apple Captive Network Assistant and will result in the WiFi being dropped on the client if a successful web authentication is not detected - this causes issues stepping through an enrolment workflow such as the MDPS one you are testing.
    Take a look at this feature in Amigopod designed to bypass the display of this mini browser and allow you to leverage the native Safari browser for the entire provisioning process.
  • 3.  RE: MDPS Issue with iOS
    Posted Mar 27, 2012 11:09 PM
    Hi Cam,
    Sorry for the delay in responding, yes we were using open SSID and using 5.0.3 on controller so sounds like you're right on the money with this one.
    I will suss this out with  the client and see if we can get it going.
    Thanks again
    Scott
