Network Management
Measure response time of IP addresses on the network
  • 1.  Measure response time of IP addresses on the network
    Posted May 19, 2022 11:24 AM
    I need to get the response time of the various L3 hops along a path between my iMC server and a device in Azure.
    I only found the "Response Time of Device" index, but this does only gives the time it takes to the device to answer on its management interface.
    Is it possible to configure iMC to ping various IP addresses with a non-standard size (size of 1000 bytes) and to measure the time it took to answer ? I would then be able to display these values in a real-time monitoring graph for the monitoring team.
    Brgds,
    Christian Piercot
    Christian Piercot
