Memory Disparity on the Aruba Controller(s)
  • 1.  Memory Disparity on the Aruba Controller(s)
    Posted Sep 11, 2015 06:34 AM
    Hi All,
    We are observing Differences in the Memory on our 3400 Cotroller.
    One of the Box is 691Mb whereas on the other we see 1.5Gb.
    Please check with the Show Inventory / Show Switchinfo and Show Version details of both our Controllers.
    Primary ::
    show memory
    Memory (Kb): total: 691780, used: 632676, free: 59104
    #show inventory
    Supervisor Card slot : 0
    System Serial# : AK0030811
    SC Assembly# : 2010051C (Rev:12.00)
    SC Serial# : F02298726 (Date:02/20/14)
    SC Model# : Aruba3400
    HW MAC Addr : 00:0B:86:6F:0F:70 to 00:0B:86:6F:0F:73
    CPLD Version : (Rev: 1.3)
    Aruba3400 Card Temperatures :
    : Card Temperature 33 C
    : CPU Temperature 42 C
    Aruba3400 Fan Tachometers :
    : Chassis Fan A 3750 RPM
    : Chassis Fan B 3200 RPM
    : Chassis Fan C 4000 RPM
    : Chassis Fan D 3934 RPM
    Aruba3400 Card Voltages :
    : VMON1 3300mV 3300 mV
    : VMON2 2500mV 2532 mV
    : VMON3 AB 1800mV 1804 mV
    : VMON4 CD 1800mV 1800 mV
    : VMON5 1200mV 1222 mV
    : VMON6 1000mV 1000 mV
    #show switchinfo
    Hostname is POL05OWLCR101
    Polygon
    System Time:Fri Sep 11 15:58:16 IST 2015
    ArubaOS (MODEL: Aruba3400), Version 6.4.3.1
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-04-21 at 16:22:02 PDT (build 49733) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.1.0 (build 35189)
    Built: 2012-09-06 16:05:33
    Built by: p4build@re_client_35189
    Switch uptime is 29 days 13 hours 41 minutes 46 seconds
    Reboot Cause: Power Failure (Intent:cause:register ee:ee:0)
    Supervisor Card
    Processor XLR 516 (revision C4) with 1187M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
    Config File: default.cfg
    Boot Partition: PARTITION 0
    VLAN1 is administratively down line protocol is down
    Hardware is CPU Interface, Interface address is 00:0B:86:6F:0F:70 (bia 00:0B:86:6F:0F:70)
    Description: 802.1Q VLAN
    Internet address is 172.16.0.254 255.255.255.0
    IPv6 Router Advertisements are disabled
    Routing interface is enable, Forwarding mode is enable
    Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled Suppress ARP enable
    Encapsulation 802, loopback not set
    MTU 1500 bytes
    Last clearing of "show interface" counters 29 day 13 hr 41 min 46 sec
    link status last changed 29 day 13 hr 37 min 52 sec
    Proxy Arp is disabled for the Interface
    switchrole:master
    Configuration Changed since last save
    No crash information available.
    show version
    Switch uptime is 29 days 13 hours 42 minutes 4 seconds
    Supervisor Card
    Secondary Controller ::
    show memory
    Memory (Kb): total: 1502772, used: 618988, free: 883784
    show inventory
    System Serial# : AK0030869
    SC Serial# : F02300242 (Date:03/07/14)
    HW MAC Addr : 00:0B:86:6F:10:E4 to 00:0B:86:6F:10:E7
    : CPU Temperature 41 C
    : Chassis Fan A 4137 RPM
    : Chassis Fan B 4137 RPM
    : Chassis Fan D 3000 RPM
    : VMON1 3300mV 3306 mV
    : VMON2 2500mV 2526 mV
    : VMON3 AB 1800mV 1806 mV
    : VMON4 CD 1800mV 1798 mV
    : VMON5 1200mV 1216 mV
    show switchinfo
    Hostname is POL05OWLCR102
    Polygon
    System Time:Fri Sep 11 16:01:51 IST 2015
    Switch uptime is 106 days 8 hours 48 minutes 43 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:50)
    Supervisor Card
    Processor XLR 516 (revision C4) with 1979M bytes of memory.
    VLAN1 is up line protocol is up
    Hardware is CPU Interface, Interface address is 00:0B:86:6F:10:E4 (bia 00:0B:86:6F:10:E4)
    MTU 1500 bytes
    Last clearing of "show interface" counters 106 day 8 hr 48 min 43 sec
    link status last changed 54 day 2 hr 50 min 52 sec
    switchrole:local
    masterip:10.187.128.101
    IKE PSK: ad61a2c63f06de3f84cba95255bcb6a15ed1db63b8da4c43
    show version
    Switch uptime is 106 days 8 hours 48 minutes 59 seconds
    Supervisor Card
  • 2.  RE: Memory Disparity on the Aruba Controller(s)
  • 3.  RE: Memory Disparity on the Aruba Controller(s)
    Posted Sep 14, 2015 02:37 AM
    Let's use this thread for the memory disparity, the other can be used to do a quick check of the in use memory (which i suspect is fine)
    The issue here is no so much about free memory, rather that the two controllers have different installed totoal memory sizes, they are in fact using about the same amount of memory (~ 600M)
    Primary
    Secondary
    I strongly suspect this is a case of due to parts availability/cost associated with older parts where manufacturing is giving away free/extra memory in because it's cheaper than the old memory parts.
    I will find out some more info and update.
    regards
    -jeff
  • 4.  RE: Memory Disparity on the Aruba Controller(s)
    Posted Sep 21, 2015 05:03 AM
    Hi Jeff,
    Thanks for info shared, Both are controller(s) are using almost same Memory, however seeing both the Controllers with different Memory is somthing which are considering.
    FYI, we have purchased both the Controller(s) at the same instance (approx 2 years ago). We have moved all the AP's to the Secondary Controller(s) which is acting as Local and seeing better usage stats from our Airwave. Please check with the attachment.
  • 5.  RE: Memory Disparity on the Aruba Controller(s)
    Posted Oct 18, 2015 10:22 AM
    hey Jeff, did you ever get to the bottom of this? or was in handled of board?
  • 6.  RE: Memory Disparity on the Aruba Controller(s)
    Posted Oct 18, 2015 10:27 AM
    Hi MVP,
    We have opened a Case with the TAC team and got the Older Controller (Low Memory) replaced .
  • 7.  RE: Memory Disparity on the Aruba Controller(s)
    Posted Oct 18, 2015 12:00 PM
    This surprises me. There is no recourse for claiming an rma on this. It's a freebie memory upgrade by Aruba due to cost of the older memory DIMMS.
    Regards
    Jeff
